Join Debian 11/12 to Nethserver 7 Active Directory
Hi there!!!
This insturccions are not working with Debian 11 / 12, i don’t like the CID application (too invasive) and buggy (some times it locks ) and doesn’t accept GPOs.
Any help will be aprecciated.
Join in Windows Active Directory Domain with Realmd.
Hi there again.
Following the steps it says: su: Error del sistema.
When I login it doesn’t create home directory.
I did a Test on a virtual Debian 12 (mate) machine and it worked like expected:
fausp thanks!!! have You put the machine inside NAT? I have to probe in the server from work…
I’ll have to do the steps again. don´t know where is the mistake.
¿Can yo send the config?
Thank in advance.
The Windows Server 2019 and the debian12 was in the same subnet.
I did the exact same steps: Join Windows AD
That’s the problem, Is not a Windows server is a NethServer were I’m trying join. I will repeat the steps and try to know where si te mistake in the config.
Worked also with a Nethserver 7.9 AD Domain:
gives this error… in a fresh debian 11 instalation.
Don’t know what to do, help will be apreciated.
