Hello. On the site you can download VMDK image. But immediately on ESXI it cannot be loaded. There you need to download OVF and VMDK files! Therefore, I created one general image on the VMware Workstation. After I converted it to the OVF file. Then I installed Node 1. There is no problem.
However, after I created the second car on the ESXI from the VMware Workstation image. And when attached to the cluster, I get the following mistake:
<3> Add_node error: <4> the public key x7kdkzglcjvca0rozlplpgacoqljtr9qhunzg6ew = is already used by node 1
I thought. Most likely, a public key is created at the time of the first launch of the car or once again. And changing it as I understand it is not possible. Since I did everything from one image, I received two cars with one key. Which causes a mistake.
