NethServer Version: 7.3.1611 (rc3)
Hi I have installed a new Nethserver on my box.
When I was done installing my network did not receive an IP address, so I had to add one with ifconfig command.
Not sure if that is relevant but hey.
The server works okay, but I have some issues. special related to network and samba
If I update either a samba share or network connection I get an error message briefly.
I tried to capture it. but its a bit weak since it dissapeared fast.
I can change the network settings like DHCP or Static.
But samba will not update.
I can create a share but can’t find it on the network after.
if I browse the server it has no shares.
Anyone have any idea.
I don’t want to reinstall the server, because I need to have this server online as close to 100%
and voila it works properly again.
Thanks
Now the enp6s0 is un-configured.
So was probably that who caused the problem.
the smb.conf is now updating just fine
Well at least I’m learning something more all the time about nethserver and CentOS
