Issues with Nextcloud when container is installed on external mount
On a fresh NS8 install, following the Disk migration guideline Disk usage, causes a number of issues when/after installing the Nextcloud App.
During install, i get the following error:
*{“error”:"_acontrol_task request attempt failed (WS reached EOF while waiting for module/traefik1/task/a785bd98-ba56-4b24-a103-635c7894d8cd). Retrying…\nCreated symlink /home/nextcloud1/.config/systemd/user/default.target.wants/nextcloud.service → /home/nextcloud1/.config/systemd/user/nextcloud.service.*
Warning: require_once(/var/www/html/lib/versioncheck.php): Failed to open stream: No such file or directory in /var/www/html/console.php on line 34\r\n\r\nFatal error: Uncaught Error: Failed opening required ‘/var/www/html/lib/versioncheck.php’ (include_path=‘.:/usr/local/lib/php’) in /var/www/html/console.php:34\r\nStack trace:\r\n#0 /var/www/html/occ(11): require_once()\r\n#1 {main}\r\n thrown in /var/www/html/console.php on line 34\r\n"}}
This error only occures only if /home have been migrated to an external mount(mounted as /home)
Although Nextcloud can be used afterwards, I encounter issues with adding email notification:
A problem occurred while sending the email. Please revise your settings. (Error: Email could not be sent. Check your mail server log)
As well as connecting to external storage(SMB).
Did you try using the wireguard IP 10.5.4.1 in Nextcloud Basic settings?
Using the local IP of NS8 in Nextcloud External Storage settings worked:
This resolved the issue with the SMB connection. Why is this the case, shouldn’t it work with hostnames?
Probably some alias missing in the internal DNS…
This is great. Although the solution, I’m sure, is just temporary.
That does not explain the issues I encountered in relation to the symlink problem, when the container had been moved to an external mount.
Did you try the samba DC hostname?
See also No access to Samba Shares - #2 by mrmarkuz
I tested the script, installed Nextcloud and it seems to work. Are there still issues regarding the mail notification? If yes, do you use a mail app instance or SMTP?
I got this error too but I think it can be ignored as traefik is working after installation.
This is not an error, the service for nextcloud was enabled which creates a symlink.
I didn’t get this one, can you reproduce it for example by restarting Nextcloud or click “Save” in the Cluster-admin Nextcloud app settings?
If the following command works, versioncheck should be ok, see also Failed opening required '/var/www/html/lib/versioncheck.php' · Issue #584 · nextcloud/helm · GitHub
runagent -m nextcloud1 occ
Hey mrmarkuz!
Thank you for your many questions. Really appreciate it.
I do not recall, I have a number of alias for the main IP, but I will try to use this next time.
Happy to see that I’m not the only one getting this. Just worried that this might cause issues down the road. I only get this error after I have migrated to an external disk. I have done this a couple of times, using the same procedure and domain information.
I tried both SMTP and mail app, none would go through.
Nextcloud can start and “seems” to work fine.
I will gather some more information on this.
I have tried with a different domain setup and I did not get the error.
At this point I must assume that I have an unresolved DNS in my original setup and as such the issue is not related to me migrating /home to an external HDD.
Thank you for your help so far!
Could I ask you to try this again, once you have migrated /home to an older slower (non-ssd) drive?
An SSD is required, see also System requirements — NS8 documentation
I agree! It is, however, tempting to place larger amounts of user data on cheaper hardware than SSDs.
