Hi I’m having issues with the httpd not starting. I’m not quite sure whats wrong. Only thing I tried to do today was renew certificates and then after that, nothing worked. I tried updated the whole system. The update looks like it went through.
When I tried to update from the software center, it runs through the update then fails. However, when i go to the terminal and try ‘yum update’ it tells me that theres nothing new to update.
I tried renewing certificates however, it tells me letsencripte/update failed
then I noticed in services ‘httpd’ was not started and then when i try to start it, it tells me that the update fails also.
Any suggestions. I’ve included screenshots for this last issue
. Thank you so much!
NethServer Version: your_version v7
Module: your_module httpd
