I just downloaded the latest version (7.7.1908) for testing but having some issues with web-filter (1.10.1). Can anyone help me please?
Below is my configuration:
I have selected Green Zone as Transparent SSL because I don’t want to configure proxy settings on hosts manually.
I haven’t created any proxy rules at this point.
I have downloaded Shalla (free for non-commercial use) and all categories are available.
I have strictly prohibited movies, social-net, porn in default profile as well as added youtube and facebook in global black list but still I am able to browse everything.
Dear @mrmarkuz many thanks for your reply, I have tried troubleshooting hints provided in official documentation but no luck.
I have verified the followings:
the client is surfing using the proxy
NO, clients is not using manually configured proxy, because I have set the proxy mode to SSL Transparent, and as per the documentations I think no client end configuration is required.
the client doesn’t have a configured bypass inside Hosts without proxy section
Yes, I haven’t created any bypass rule for hosts without proxy.
the client is not browsing a site with a configured bypass inside Sites without proxy section
Yes, I haven’t created any bypass rule for sites without proxy.
the client is really associated with a profile not allowed to visit the page
I haven’t created any custom profile, all clients are using default profile in which some categories are blocked.
the client is surfing within a time frame when the filter is permissive
No specific time frame is defined, Its default 24/7.
Many thanks for your support @dnutan.
I have moved from transparent ssl mode to manual as well as blocked http & https ports.
Although I will have to manually configure clients to use proxy but now the web-filter is working as it supposed to be.
I guess issue was with ssl transparent mode.
