Issue in update module
yum
updates
v7
(Francesco) #1
NethServer Version: 7.5.1804
Module: update module
Hi guys, I have a problem whit the update module.
I have this error
failure: repodata/repomd.xml from centos-sclo-rh: [Errno 256] No more mirrors to try. http://mirror.centos.org/centos/7/sclo/x86_64/rh/repodata/repomd.xml: [Errno -1] Error importing repomd.xml for centos-sclo-rh: Damaged repomd.xml file
Il comando di aggiornamento/installazione potrebbe essere fallito a causa di problemi nella cache dei metadati. Pulire la cache facendo clic sul pulsante in basso e ripetere l'operazione di installazione/aggiornamento.
Can you help me ?
Thanks in advance
Francesco
(Francesco) #2
whit this command:
yum clean all && rm -rf /var/cache/yum && yum -y update
I have:
Cleaning repos: base centos-sclo-rh centos-sclo-sclo epel extras nethforge
              : nethserver-base nethserver-updates updates
Cleaning up everything
Maybe you want: rm -rf /var/cache/yum, to also free up space taken by orphaned d        ata from disabled or removed repos
Cleaning up list of fastest mirrors
Determining fastest mirrors
epel/x86_64/metalink                                     |  32 kB     00:00
 * base: ba.mirror.garr.it
 * epel: pkg.adfinis-sygroup.ch
 * extras: ba.mirror.garr.it
 * nethforge: mirror2.nethserver.org
 * nethserver-base: mirror2.nethserver.org
 * nethserver-updates: mirror2.nethserver.org
 * updates: ba.mirror.garr.it
base                                                     | 3.6 kB     00:00
centos-sclo-rh                                           | 3.8 kB     00:00
Trying other mirror.
 One of the configured repositories failed (CentOS-7 - SCLo rh),
 and yum doesn't have enough cached data to continue. At this point the only
 safe thing yum can do is fail. There are a few ways to work "fix" this:
     1. Contact the upstream for the repository and get them to fix the problem.
     2. Reconfigure the baseurl/etc. for the repository, to point to a working
        upstream. This is most often useful if you are using a newer
        distribution release than is supported by the repository (and the
        packages for the previous distribution release still work).
     3. Run the command with the repository temporarily disabled
            yum --disablerepo=centos-sclo-rh ...
     4. Disable the repository permanently, so yum won't use it by default. Yum
        will then just ignore the repository until you permanently enable it
        again or use --enablerepo for temporary usage:
            yum-config-manager --disable centos-sclo-rh
        or
            subscription-manager repos --disable=centos-sclo-rh
     5. Configure the failing repository to be skipped, if it is unavailable.
        Note that yum will try to contact the repo. when it runs most commands,
        so will have to try and fail each time (and thus. yum will be be much
        slower). If it is a very temporary problem though, this is often a nice
        compromise:
            yum-config-manager --save --setopt=centos-sclo-rh.skip_if_unavailabl        e=true
(Francesco) #3
SOLVED :grin:
I just set “Locked” on “Software updates origin”
Now all works fine
Thanks
