Issue downloading updates - Error
Good afternoon all, i could have sworn i have seen a fox for this error but maybe someone can point me in the right direction.
Getting a daily email from nethserver, started 3 days ago
error: RPC failed; result=18, HTTP code = 200
fatal: The remote end hung up unexpectedly
fatal: early EOF
fatal: index-pack failed
[ERROR] Can’t download ipsets repository
Any thoughts and idea’s, greatly appreciated
rob
From which ipsets repository?
One solution is to increase the buffer used by git from the unix command by exporting this environment variable:
export GIT_HTTP_MAX_REQUEST_BUFFER=100M
You may do that once for all using the git config command:
git config --global http.postBuffer 100000000
(Source)
Thanks Marc will give that a go, cheers for the help
rob
