Is Installation of NS8 on ARM supported?
I have been trying to install NS8 on rocky linux on An ARM based Server, but have not been successfull, is it supported?
I am gettign the errors
[rocky@mygen ~]$ curl https://raw.githubusercontent.com/NethServer/ns8-core/ns8-stable/core/install.sh | bash
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100  2575  100  2575    0     0   5786      0 --:--:-- --:--:-- --:--:--  5773
Checking port 80 and 443 are not already in use
Restart journald:
Failed to restart systemd-journald.service: Interactive authentication required.
See system logs and 'systemctl status systemd-journald.service' for details.
AFAIK, ARM is not planned for the moment…
"Other building sites…)
:slight_smile:
And the way ARM is coming up strongly and overtaking all other legacy x86/amd64
Ok, noted.
Yes, but none of those upcoming ARMs are yet running NS7, that’s why migration has priority!
:slight_smile:
If NS8 works, including migration, ARM is more or less “easy”…
There will be caveats, libraries not quite translated, etc - Rome wasn’t built in a day.
But it will happen!
Ok My Bad, i thought i could save some few Coins by deploying NS8 on an ARM based Instance, seems id have to wait, if its to be supported.
I’m sure the devs are glad for anyone testing (also ARM) - but ask the devs directly…
