Hello,
I’ve installed new NethServer 7.9.2009 which seems to have problem with adding multiple Remote subnets to IPSec tunnel. It accepts only first entry. Other are not respected. I didn’t find them in “route” shell command and it also doesn’t work. Workaround is to add entries manually…
Please fix.
Sorry, I’ve found that issue applies only when IKE Version is set to “Force IKEv2”. When set to “IKEv2” it just works
