The Overview page of the IPS loads forever. How to fix it?
@carsten would you provide “a bit more information” about your case?
Pretty please with (cherry) shell on top
What information do you need? It just hangs at the IPS site overview site. The other subitems such as “configuration” work. I also tried to disable and reenable the IPS, but to change. Where to look for further details?
Starting from beginning, current hardware configuration of your installation, roles/modules installed, something “around bare metal”, like the bandwidth use.
Moreover: fresh install or upgraded? First time that you install IPS?
Its a VM and it was just upgraded from 7.8.2003 to 7.9.2009. However in 7.8.2003 the problem already appeared at a certain point. I hoped to get rid of it with the upgrade, but unfortunately not.
I just found the solution:
rm -f /var/lib/evebox/*
systemctl restart evebox
Well done, @carsten
