Hi All,
Not a linux noob, but for the life of me i can’t figure where i’ve gone wrong.
A fresh install on a new server, entered all the network information when setting up and the installation seems to have ignored the manual settings for the network.
The hostname is all ok, but the IP address is being retrieved via dhcp and not the fixed ip i set in the installer.
To make matters stranger i can ping, the assigned dhcp address, but cannot get the webadmin as i get a ‘problem loading page error’
The ip address assigned by dhcp is 192.168.255.175 so i’m trying https://192.168.255.175:980
Any idea whats wrong and how can I set the IP manualy from the console as nothing i’ve read up on so far has worked - usually returning command not found.
Thanks in advance for any help/advice.
Cheers
