How do i install and enable ioncube loader?
Also, how do i enable mod rewrite?
Benn trying to install an app, and here is an error i am getting
how do i make use of this.
What exactly are you trying to do.
ionCube is a commercial product that is not part of NS. Perhaps check with ionCube support or the support for the app you are trying to install.
Cheers.
i am trying to install a script that is encoded with ioncube.
so i am wondering how i can be able to install ioncube on nethserver.
Does anyone not host a script like blesta or whmcs using NS?
Perhaps follow the ionCube instructions.
Cheers.
