Lose the connection from the PC with Internet continuously, however if performed from the PC Nethserver ping the server (192.168.0.200) the connection is restored.
Network Configuration:
Green Network IP: 192.168.0.200 mask: 255.255.255.0 IP gateway: null
Red Network IP: 192.168.0.201 mask: 255.255.255.0 gateway: ip router (192.168.0.241)
Why does this happen? I have reinstalled and still doing the same.
Thank you. Help me please.
The connection works correctly per time to time I lose my internet connection.
performed a ping my gateway 192.168.0.200 (green nethserver ip) and recover the Internet connection
It seems an unusual behavior. I suspect the card may not have been performing well (driver problem perhaps). Try to continiously ping the router as well as an internet address like yahoo.com or google.com
It happens in two different servers in two different companies. The solution I’ve had to implement a scheduled Windows PCs 10 minutes ago ping task (Nethserver 192.168.0.200)
The problem remains the same.
When I lose the connection to the Internet if I do a ping www.google.es also becomes the connection. It is as if he lost the route where you need to go online and pinging find her again. Or that somehow the Nethserver server pinging sleep and woke up.
Just to isolate the problem, are all client PCs experiencing the same? What if you go to NethServer (while the reported computers are not able to connect to internet)…go and check if network is working (do not ping) then go back to client PCs and try again.
