NethServer Version: 7.6.1810
Module: NextCloud
is it possible to run webtop on one machine(my mailserver) and Nextcloud on a other.
and still use the Integration between webtop and nextcloud??
http://docs.nethserver.org/en/v7/webtop5.html#nextcloud-integration
Regards
Michael Nielsen
It should be possibile. When you click on “Add nextcloud resource” you can compile HOST field with the address of your nextcloud server.
Super, will test it
