“Instant messaging” module from Software Center not found (NethServer Enterprise 7.9.2009)
I wanted to point out that there is no “Instant messaging” on the available packages, to activate webchat on WebTop 5:
Source link: https://docs.nethserver.org/en/latest/webtop5.html?highlight=chat#chat-integration
how it is solvable?
Thank you community in advance for anyone who has advice or helps; and if it can also be useful to other users.
So you don’t have the community version.
Please, would you simply type “ejabber” into the search box?
Not found ejabber:
It’s called instant messaging:
Maybe try to clean yum cache and update:
yum clean all --enablerepo=*
yum update
Not found:
To workaround the problem, you may install from command line:
yum install nethserver-ejabberd
I guess it’s just an issue with the UI.
Wait. This machine is Enterprise. It seems that the key is not valid or updates are blocked. @Nix do u have a support contract with Nethesis?
Test manual installation:
Not found option in WebTop 5 admin panel:
Add (+) ‣ Services ‣ com.sonicle.webtop.core (WebTop) ‣ Resource ‣ WEBCHAT ‣ Action ‣ ACCESS
(source link: https://docs.nethserver.org/en/v7/webtop5.html#chat-integration)
Screen:
(missing function to enable WebTop 5 chat)
The package is not listed in software center as it is already installed (the it usually appears on Applications section).
NethServer Enterprise documentation:
https://nethserver.docs.nethesis.it/en/master/webtop5.html#chat-integration
I have to test the machine for a cooperative company that me trial.
The key is valid:
I also tried that guide,
(https://nethserver.docs.nethesis.it/en/master/webtop5.html#chat-integration),
the problem persists, (unfortunately :frowning: ).
Which webtop5 version do you have?
I discovered the problem:
  1. You need to log into webtop 5 as an administrator user.
  2. Click on: maintenance mode
  3. Do these operations:
  1. Click pop-up “Save & Close”
  2. Set the maintenance function to off
P.s: Specific:
the package name on enterprise is: ejabberd (Software Center)
–> Problem solved, I hope it can be of help to other users as well.
I thank community for your patience; (I’m new user).
Here is the function activated on the user side:
WebTop5 - WebChat Enabled
(message for moderators): is can close the discussion, and put: [SOLVED] ;
Thanks
You’re welcome.
If you have an enterprise I suggest you contact the Nethesis support.
Thank you guys :slight_smile: @dnutan @mrmarkuz
