Installing Nethserver atop centos i386
Could you provide me instructions to do so? i am stuck here Cannot find a valid baseurl for repo: centos-base
Could not retrieve mirrorlist http://mirrorlist.nethserver.org/6.6/centos?release=6&repo=os&arch=i386 error was
14: PYCURL ERROR 22 - “The requested URL returned error: 404 Not Found”
Any help would be appreciated. Maybe i even discovered a bug.
This is on a standard centos 6.6 install.
Nethserver is x86_64 only… your arch (i386) is not supported
you are supposed to use a minimal CentOS distro x86_64 and install NethServer if you like this to work properly.
