Sepp1945
(Josef Schembera)
1
NethServer Version: 7.9
Module: MatterMost
i have installed Mattermost and want to activate it as directed with
config setprop mattermost VirtualHost mattermost.yourdomain.com status enabled signal-event nethserver-mattermost-update
but it returns … config not found.
Please help
Sepp
dnutan
(Marc)
2
Greetings!
You have installed nethserver-mattermost rpm package (Team Chat (Mattermost) module).
These are two different commands (just in case it is a formatting error on the original post):
Sepp1945
(Josef Schembera)
3
Thank you,
the problem is that the command “config” is not accepted
Sepp
Sepp1945
(Josef Schembera)
5
Thank you very much
this worked very well tjhis is the solution
Sepp
