This Howto is obsolete – It is now possible to install a custom certificate for Samba DC from the TLS Certificates page, as for any other application. Read carefully the note about self-signed certificates and custom certification authorities, and make sure the DC FQDN is included in the certificate SANs.
Hello all.
Today I would like to share how you can configure Samba to use your custom certificate for LDAPS.
First, we must place the the .crt and .key files into the container.
Use the following command to enter the container environment (notice if your samba instance number is different):
sudo /usr/local/bin/runagent -m samba1 podman exec -it samba-dc /bin/bash
Check, that your shell prompt is changed to root@dc1.
Then you can use cat to output each cert contents into a file:
- Type
cat > /etc/samba/cert.key << EOFand press Enter - Paste the contents of your key file and press Enter to add another new line
- Type
EOFand press Enter
New /etc/samba/cert.key file should be created.
Repeat this operation for .crt.file.
Now we must set permissions for the .key file, otherwise Samba will refuse to use it.
chmod 0600 /etc/samba/cert.key
You can check permissions and if your files have the correct SELinux settings:
ls -laZ /etc/samba/
total 32
drwxr-xr-x. 3 root root system_u:object_r:container_file_t:s0 145 Aug 28 12:37 .
drwxr-xr-x. 1 root root system_u:object_r:container_file_t:s0:c26,c233 55 Jul 24 09:04 ..
-rw-r--r--. 1 root root unconfined_u:object_r:container_file_t:s0 1403 Aug 28 09:36 cert.local.crt
-rw-------. 1 root root unconfined_u:object_r:container_file_t:s0 1704 Aug 28 09:36 cert.key
-rw-r--r--. 1 root root unconfined_u:object_r:container_file_t:s0 8 Aug 7 2023 gdbcommands
-rw-r--r--. 1 root root unconfined_u:object_r:container_file_t:s0 201 Aug 28 12:37 include.conf
-rw-r--r--. 1 root root system_u:object_r:container_file_t:s0 1260 Aug 28 15:33 smb.conf
-rw-r--r--. 1 root root unconfined_u:object_r:container_file_t:s0 8917 Apr 8 2024 smb.conf.distro
From the container point of view the files are owned by root, but in a system-wide context it will be your container user.The SELinux setting should be like this: unconfined_u:object_r:container_file_t:s0
If it’s not, exit the container then use sudo chcon -R -t container_file_t /home/samba1/.local/share/containers/storage/volumes/config/_data/
Now when the files are in place, we can edit the include.conf file, it will be easier from the outside of the container, so exit it.
sudo nano /home/samba1/.local/share/containers/storage/volumes/config/_data/include.conf
Add the following lines:
tls enabled = yes
tls keyfile = /etc/samba/cert.key
tls certfile = /etc/samba/cert.crt
Restart your Samba container:
sudo /usr/local/bin/runagent -m samba1 podman restart samba-dc
You can check if the SSL cert has been used by running this command:
openssl s_client -showcerts -connect dc.mydomain.local:636
