yes, unattended seems ok, also if in the anaconda gui the network is not shown as "connected " as is in the rc2 gui, at the end the eth correctly take ip from dhcp server (tested with one eth)
confirmed 1,2,3
4. in my tests i didn’t have problem with password, i think it’s a consequence of 2
i need some more time to make other tests with 2eth red/green config
I tried it yesterday with an unattended installation. It works without problems and the password can be changed without any problems.
Only the login in SOGo in connection with the Samba AD does not work.
But that is another issue.
But what I would like to say is that all the creators and developers involved in the development of Nethserver 7 do a great job. And we users do well to consider that all this is not yet finished.
Mmmm I think the final will be released in the new year, but also I don’t expect any major change between RC3 and final. (@davidep@filippo_carletti feel free to say your idea!).
probably i’m little anxious but after the problems with anaconda in rc3 i would like to test installation from iso before the final release, if possible
I´ve also regcognized that- I´m using a german keyboard which is functioning in the VM console partly when I choose the english and not the german one.
tested basic interactive install and (ofcourse) all goes well… i need some time to test installation with 2 eth…
great work and tnx again for having calmed my anxiety
