Installation issues on centos 6.8 minimal
Hello from a minimal install of centos 6.8 I can not install nethserver when I send the command
"Yum -y localinstall http://mirror.nethserver.org/nethserver/nethserver-release-6.rpm" I get this error
"Error: Package: nethserver-release-6.8-1.ns6.noarch (/ nethserver-release-6)
Requires: nethserver-firewall-based
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest "
Is there any solution?
Thank you
P.S. This is an on-line translation
Hi @Vinny74 You follow these steps: http://docs.nethserver.org/en/latest/installation.html#install-on-centos.
Add the repo NethServer
Regards
Please follow also this thread
@Vinny74 have you sort it out yet? Please mark this thread as resolved.
