Installation has frozen for over 12 hours
NethServer Version: 7.7.1908
Module: Event: nethserver-mysql-update
i was installation some apps on my syetsm and installation froze, its been like that since yesterday
on terminal this is what i get
Another app is currently holding the yum lock; waiting for it to exit...
  The other application is: pkgaction
    Memory : 199 M RSS (536 MB VSZ)
    Started: Mon May  4 14:57:07 2020 - 9:19:47 ago
    State  : Sleeping, pid: 9139
    Started: Mon May  4 14:57:07 2020 - 9:19:49 ago
    Started: Mon May  4 14:57:07 2020 - 9:19:51 ago
Edit!!! If the server is virtualized you should do a snapshot before the following steps!
You could try to kill the yum process.
kill yum
If it doesn’t work:
kill yum -9
After killing it you should do
yum-complete-transaction
yum clean all
because it can be leaved in an inconsistent state after killing.
After these steps you should try
yum update
from terminal.
-bash: kill: yum: arguments must be process or job IDs
sorry my fault. Try
pkill yum
or
killall yum
or get the id with:
ps -A | grep yum
so, i have run the command, all cleared, but now. the interface still has the running process unending
Did you kill the process?
even after reloading the page?
yap, have tried over and over again.
this is the second time after rebuild that it happens
maybe the process to kill is pkgaction? I don’t know
i just had to rebuild the server. ill monitor closely, if the issue persisit,s then ill install the apps one by one till i notice which one of the apps causes the problem in the first place
