Hi Folks
Thoughts on nethserver 8 install on debian please - ive managed to build a flakey cluster on debian 11 when i include debian desktop environment/gnome in the build but when i excluded these items i get the result below - this is a bare debian 11 install (only updates are to /etc/hosts /etc/hostname /etc/network/interfaces and installed net-tools). This is a proxmox vm btw
Cheers
Alex
alex@70neth56:~$ su -
Password:
root@70neth56:~#
root@70neth56:~#
root@70neth56:~#
root@70neth56:~# ping google.com
PING google.com (142.250.187.238) 56(84) bytes of data.
64 bytes from lhr25s34-in-f14.1e100.net (142.250.187.238): icmp_seq=1 ttl=56 time=9.37 ms
64 bytes from lhr25s34-in-f14.1e100.net (142.250.187.238): icmp_seq=2 ttl=56 time=9.40 ms
^C
— google.com ping statistics —
2 packets transmitted, 2 received, 0% packet loss, time 1002ms
rtt min/avg/max/mdev = 9.373/9.384/9.396/0.011 ms
root@70neth56:~# apt-get update && apt-get upgrade -y && apt-get install -y curl
Hit:1 Index of /debian-security bullseye-security InRelease
Hit:2 Index of /debian bullseye InRelease
Hit:3 Index of /debian bullseye-updates InRelease
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
Calculating upgrade… Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
The following additional packages will be installed:
libcurl4
The following NEW packages will be installed:
curl libcurl4
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 617 kB of archives.
After this operation, 1,198 kB of additional disk space will be used.
Get:1 Index of /debian bullseye/main amd64 libcurl4 amd64 7.74.0-1.3+deb11u7 [346 kB]
Get:2 Index of /debian bullseye/main amd64 curl amd64 7.74.0-1.3+deb11u7 [270 kB]
Fetched 617 kB in 0s (4,744 kB/s)
Selecting previously unselected package libcurl4:amd64.
(Reading database … 32671 files and directories currently installed.)
Preparing to unpack …/libcurl4_7.74.0-1.3+deb11u7_amd64.deb …
Unpacking libcurl4:amd64 (7.74.0-1.3+deb11u7) …
Selecting previously unselected package curl.
Preparing to unpack …/curl_7.74.0-1.3+deb11u7_amd64.deb …
Unpacking curl (7.74.0-1.3+deb11u7) …
Setting up libcurl4:amd64 (7.74.0-1.3+deb11u7) …
Setting up curl (7.74.0-1.3+deb11u7) …
Processing triggers for man-db (2.9.4-2) …
Processing triggers for libc-bin (2.31-13+deb11u6) …
root@70neth56:~# curl https://raw.githubusercontent.com/NethServer/ns8-core/main/core/install.sh | bash
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 3109 100 3109 0 0 6410 0 --:–:-- --:–:-- --:–:-- 6423
Checking machine hostname
Checking port 80 and 443 are not already in use
Restart journald:
Install dependencies:
System not supported
root@70neth56:~#
