Hi, i’m completely new here, and not a strong CentOS admin.
i tryied to install Nethserver on Cent=S, everything looks like good but if i go to my https://privateipaddress:980 i recieve an error, the browser can’t find adress.
Ok, probably my problem is deeper then nethserver…
i see ipv4 in my ifconfig.
but i can’t access to ssh… so i have to understand why i can ping other machines, and other machines can ping the server,anyway, after install nethserver i didn’t start the service, how can i do it?
thank you
M.
Mauro, did you configure the interfaces correctly ?
Double check if you are connected to the right ETH interface card. (it happened to me one time).
Also try to reboot NS and see if it works after that.
