I have 10 hosts with scattered IP addresses.
I need to inhibit the internet connection to all 10 hosts at the same time. What is the simplest solution and free of possible “side effects” to achieve what I want?
Hi @nicovon i think you need to tell a bit more about your environment, for providing you the less painful way to achieve what you’re looking for
And a bit more about these hosts.
NethServer release 7.9.2009 (final)
kernel version: 3.10.0-1160.31.1.el7.x86_64
the 10 hosts are computers with Windows 10 Pro
@nicovon still “poor info”, unfortunately. Starting from your environment.
Anyway, you asked for…
If these devices should not go at all on internet, you can arrange different ways to stop them getting on the net.
This is only one…
192.168.2.201
to 192.168.2.211
)Obviously the devices will know that internet is no more available, and windows update as all services will complain about that.
should the rule be created in this tab (network services)?
Firewall section, not network services.
@nicovon it’s an english forum, post screenshot in english.
I am italian and i understand anyway, but others don’t
Io sono italiano e capisco ugualmente, ma gli altri no!
okay like this?
Check the box for write to log and… check the log
If you will have the result you’re looking for, you can disable the logging options.
IMVHO shold be OK.
the result I was looking for is obtained with the rule set like this:
in short, if I set destination in “Role red” the hosts continue to have internet connection, while if I set destination in “Any” the hosts have no internet connection, that is what I wanted to achieve.
Is it normal that I have to set destination in “Any” to be able to inhibit the internet connection to hosts? shouldn’t it be enough to set destination in “Role red”?
