Info Update Nethserver release 7.9.2009
NethServer Version: NethServer release 7.9.2009 (final)
Module: ** Nextcloud 1.16.4 | Antivirus 1.5.1 | Email 2.29.7 | Fail2ban 1.5.7 | Web server 3.12.0 | WebTop 1.6.10
I hav update this version and changelog is this
Is it possible or there is a problem
Thank you very mutch
Listing 1 changelog
==================== Updated Packages ====================
certbot-1.11.0-2.el7.noarch epel
  • “–preferred-chain” should only match root name (#2010217)
httpd-tools-2.4.6-97.el7.centos.5.x86_64 ce-updates
  • Thu Mar 24 13:00:00 2022 CentOS Sources bugs@centos.org - 2.4.6-97.el7.centos.5
  • Remove index.html, add centos-noindex.tar.gz
  • change vstring
  • update welcome.conf with proper aliases
openldap-servers-2.4.44-25.el7_9.x86_64 ce-updates
  • Fix CVE-2020-25709 openldap: assertion failure in Certificate List syntax validation (#2040539)
  • Fix CVE-2020-25710 openldap: assertion failure in CSN normalization with invalid input (#2040538)
nss-tools-3.79.0-4.el7_9.x86_64 ce-updates
  • fix regression for pkcs12.
fail2ban-shorewall-0.11.2-3.el7.noarch epel
  • Address CVE-2021-32749.
glibc-common-2.17-326.el7_9.x86_64 ce-updates
  • resolv: Handle DNS transaction ID collisions (#2065058)
iwl4965-firmware-228.61.2.24-80.el7_9.no ce-updates
  • Update Intel Bluetooth firmwares (rhbz 1895787)
nethserver-mail-filter-2.32.1-1.ns7.noar nethserver-updates
  • rsync disaster recovery introduces permissions issue - Bug NethServer/dev#6691
ca-certificates-2022.2.54-74.el7_9.noarc ce-updates
  • Update to CKBI 2.54 from NSS 3.79
  • Removing:
  • # Certificate "TrustCor ECA-1"
  • # Certificate "TrustCor RootCert CA-2"
  • # Certificate "TrustCor RootCert CA-1"
  • # Certificate "Network Solutions Certificate Authority"
  • # Certificate "COMODO Certification Authority"
  • # Certificate "Autoridad de Certificacion Raiz del Estado Venezolano"
  • # Certificate "Microsec e-Szigno Root CA 2009"
  • # Certificate "TWCA Root Certification Authority"
  • # Certificate "Izenpe.com"
  • # Certificate "state-institutions"
  • # Certificate "GlobalSign"
  • # Certificate "Common Policy"
  • # Certificate "A-Trust-nQual-03"
  • # Certificate "A-Trust-Qual-02"
  • # Certificate "Autoridad de Certificacion Firmaprofesional CIF A62634068"
  • # Certificate "Government Root Certification Authority"
  • # Certificate "AC Raíz Certicámara S.A."
nss-softokn-3.79.0-4.el7_9.x86_64 ce-updates
  • increase the cache for the pbe
nss-util-3.79.0-1.el7_9.x86_64 ce-updates
  • Rebase to NSS 3.79
nettle-2.7.1-9.el7_9.x86_64 ce-updates
  • Port fixes for potential miscalculation in ecdsa_verify (#1943156)
gzip-1.5-11.el7_9.x86_64 ce-updates
  • fix an arbitrary-file-write vulnerability in zgrep
    Resolves: CVE-2022-1271
rpm-4.11.3-48.el7_9.x86_64 ce-updates
  • Fix double-free in previously added patch (#2004228)
sssd-client-1.16.5-10.el7_9.13.x86_64 ce-updates
  • Resolves: rhbz#2079441 - SSSD update prompts for smartcard pin twice - After update to 7.9 [rhel-7.9.z]
  • Resolves: rhbz#2073352 - Use right sdap_domain in ad_domain_info_send [rhel-7.9.z]
kernel-tools-3.10.0-1160.76.1.el7.x86_64 ce-updates
  • sfc: complete the next packet when we receive a timestamp (Íñigo Huguet) [1793280]
screen-4.1.0-0.27.20120314git3c2946.el7_ ce-updates
  • Thu Feb 18 13:00:00 2021 Josef Ridky jridky@redhat.com - 4.1.0-0.27.2012314git3c2946
  • fix CVE-2021-26937 (#1927063)
nethserver-directory-3.4.3-1.ns7.noarch nethserver-updates
  • Ejabberd TLS Handshake Failure - Bug NethServer/dev#6409
samba-client-libs-4.10.16-20.el7_9.x86_6 ce-updates
  • Tue Aug 30 14:00:00 2022 Andreas Schneider asn@redhat.com - 4.10.16-20
  • resolves: #2119058 - Fix possible segfault in winbind
virt-what-1.18-4.el7_9.1.x86_64 ce-updates
  • Add Nutanix AHV support
    resolves: rhbz#xxx
netdata-data-1.36.1-1.el7.noarch epel
  • Update from upstream
1:java-1.8.0-openjdk-1.8.0.345.b01-1.el7 ce-updates
  • Update to shenandoah-jdk8u345-b01 (GA)
  • Update release notes for 8u345-b01.
  • Resolves: rhbz#2112383
zlib-1.2.7-20.el7_9.x86_64 ce-updates
  • Resolves: CVE-2018-25032
rh-php73-php-zip-7.3.33-1.el7.x86_64 ce-sclo-rh
  • rebase to 7.3.33 #2100753
  • fix uninitialized array in pg_query_params() leading to RCE
    CVE-2022-31625
nethserver-firewall-base-3.19.0-1.ns7.no nethserver-updates
  • Netdata 1.35.1-3 breaks traffic shaping chart - Bug NethServer/dev#6695
  • QoS class #16 is not respected - Bug NethServer/dev#6690
2:microcode_ctl-2.1-73.14.el7_9.x86_64 ce-updates
  • Tue May 10 14:00:00 2022 Eugene Syromiatnikov esyr@redhat.com - 2:2.1-73.14
  • Update Intel CPU microcode to microcode-20220510 release, addresses
    CVE-2022-0005, CVE-2022-21131, CVE-2022-21136, CVE-2022-21151 (#2090246,
    • Addition of 06-97-02/0x03 (ADL-HX C0) microcode at revision 0x1f;
    • Addition of 06-97-05/0x03 (ADL-S 6+0 K0) microcode (in
      intel-ucode/06-97-02) at revision 0x1f;
    • Addition of 06-bf-02/0x03 (ADL C0) microcode (in intel-ucode/06-97-02)
      at revision 0x1f;
    • Addition of 06-bf-05/0x03 (ADL C0) microcode (in intel-ucode/06-97-02)
      at revision 0x1f;
    • Addition of 06-97-02/0x03 (ADL-HX C0) microcode (in
      intel-ucode/06-97-05) at revision 0x1f;
    • Addition of 06-97-05/0x03 (ADL-S 6+0 K0) microcode at revision 0x1f;
    • Addition of 06-bf-02/0x03 (ADL C0) microcode (in intel-ucode/06-97-05)
      at revision 0x1f;
    • Addition of 06-bf-05/0x03 (ADL C0) microcode (in intel-ucode/06-97-05)
      at revision 0x1f;
    • Addition of 06-9a-03/0x80 (ADL-P 6+8/U 9W L0/R0) microcode at
      revision 0x41c;
    • Addition of 06-9a-04/0x80 (ADL-P 2+8 R0) microcode (in
      intel-ucode/06-9a-03) at revision 0x41c;
    • Addition of 06-9a-03/0x80 (ADL-P 6+8/U 9W L0/R0) microcode (in
      intel-ucode/06-9a-04) at revision 0x41c;
    • Addition of 06-9a-04/0x80 (ADL-P 2+8 R0) microcode at revision 0x41c;
      intel-ucode/06-bf-02) at revision 0x1f;
    • Addition of 06-bf-02/0x03 (ADL C0) microcode at revision 0x1f;
    • Addition of 06-bf-05/0x03 (ADL C0) microcode (in intel-ucode/06-bf-02)
      at revision 0x1f;
      intel-ucode/06-bf-05) at revision 0x1f;
    • Addition of 06-bf-02/0x03 (ADL C0) microcode (in intel-ucode/06-bf-05)
      at revision 0x1f;
    • Addition of 06-bf-05/0x03 (ADL C0) microcode at revision 0x1f;
    • Update of 06-4e-03/0xc0 (SKL-U/U 2+3e/Y D0/K1) microcode (in
      intel-06-4e-03/intel-ucode/06-4e-03) from revision 0xec up to 0xf0;
    • Update of 06-55-04/0xb7 (SKX-D/SP/W/X H0/M0/M1/U0) microcode (in
      intel-06-55-04/intel-ucode/06-55-04) from revision 0x2006c0a up
      to 0x2006d05;
    • Update of 06-5e-03/0x36 (SKL-H/S/Xeon E3 N0/R0/S0) microcode (in
      intel-06-5e-03/intel-ucode/06-5e-03) from revision 0xec up to 0xf0;
    • Update of 06-8c-01/0x80 (TGL-UP3/UP4 B1) microcode (in
      intel-06-8c-01/intel-ucode/06-8c-01) from revision 0x9a up to 0xa4;
    • Update of 06-8e-09/0x10 (AML-Y 2+2 H0) microcode (in
      intel-06-8e-9e-0x-dell/intel-ucode/06-8e-09) from revision 0xec up
      to 0xf0;
    • Update of 06-8e-09/0xc0 (KBL-U/U 2+3e/Y H0/J1) microcode (in
      to 0xf0;
    • Update of 06-8e-0a/0xc0 (CFL-U 4+3e D0, KBL-R Y0) microcode (in
      intel-06-8e-9e-0x-dell/intel-ucode/06-8e-0a) from revision 0xec up
      to 0xf0;
    • Update of 06-8e-0b/0xd0 (WHL-U W0) microcode (in
      intel-06-8e-9e-0x-dell/intel-ucode/06-8e-0b) from revision 0xec up
      to 0xf0;
    • Update of 06-8e-0c/0x94 (AML-Y 4+2 V0, CML-U 4+2 V0, WHL-U V0)
      microcode (in intel-06-8e-9e-0x-dell/intel-ucode/06-8e-0c) from
    • Update of 06-9e-09/0x2a (KBL-G/H/S/X/Xeon E3 B0) microcode (in
      intel-06-8e-9e-0x-dell/intel-ucode/06-9e-09) from revision 0xec up
      to 0xf0;
    • Update of 06-9e-0a/0x22 (CFL-H/S/Xeon E U0) microcode (in
      intel-06-8e-9e-0x-dell/intel-ucode/06-9e-0a) from revision 0xec up
      to 0xf0;
    • Update of 06-9e-0b/0x02 (CFL-E/H/S B0) microcode (in
      intel-06-8e-9e-0x-dell/intel-ucode/06-9e-0b) from revision 0xec up
      to 0xf0;
    • Update of 06-9e-0c/0x22 (CFL-H/S/Xeon E P0) microcode (in
      intel-06-8e-9e-0x-dell/intel-ucode/06-9e-0c) from revision 0xec up
      to 0xf0;
    • Update of 06-9e-0d/0x22 (CFL-H/S/Xeon E R0) microcode (in
      intel-06-8e-9e-0x-dell/intel-ucode/06-9e-0d) from revision 0xec up
      to 0xf0;
    • Update of 06-37-09/0x0f (VLV D0) microcode from revision 0x90c up
      to 0x90d;
    • Update of 06-55-03/0x97 (SKX-SP B1) microcode from revision 0x100015c
      up to 0x100015d;
    • Update of 06-55-06/0xbf (CLX-SP B0) microcode from revision 0x400320a
      up to 0x4003302;
    • Update of 06-55-07/0xbf (CLX-SP/W/X B1/L1) microcode from revision
      0x500320a up to 0x5003302;
    • Update of 06-55-0b/0xbf (CPX-SP A1) microcode from revision 0x7002402
      up to 0x7002501;
    • Update of 06-5c-09/0x03 (APL D0) microcode from revision 0x46 up
      to 0x48;
    • Update of 06-5c-0a/0x03 (APL B1/F1) microcode from revision 0x24 up
      to 0x28;
    • Update of 06-5f-01/0x01 (DNV B0) microcode from revision 0x36 up
      to 0x38;
    • Update of 06-6a-06/0x87 (ICX-SP D0) microcode from revision 0xd000331
      up to 0xd000363;
    • Update of 06-7a-01/0x01 (GLK B0) microcode from revision 0x38 up
      to 0x3a;
    • Update of 06-7a-08/0x01 (GLK-R R0) microcode from revision 0x1c up
      to 0x1e;
    • Update of 06-7e-05/0x80 (ICL-U/Y D1) microcode from revision 0xa8
      up to 0xb0;
    • Update of 06-8a-01/0x10 (LKF B2/B3) microcode from revision 0x2d up
      to 0x31;
    • Update of 06-8c-02/0xc2 (TGL-R C0) microcode from revision 0x22 up
      to 0x26;
    • Update of 06-8d-01/0xc2 (TGL-H R0) microcode from revision 0x3c up
      to 0x3e;
    • Update of 06-96-01/0x01 (EHL B1) microcode from revision 0x15 up
      to 0x16;
    • Update of 06-9c-00/0x01 (JSL A0/A1) microcode from revision 0x2400001f
      up to 0x24000023;
    • Update of 06-a5-02/0x20 (CML-H R1) microcode from revision 0xec up
      to 0xf0;
    • Update of 06-a5-03/0x22 (CML-S 6+2 G1) microcode from revision 0xec
      up to 0xf0;
    • Update of 06-a5-05/0x22 (CML-S 10+2 Q0) microcode from revision 0xee
      up to 0xf0;
    • Update of 06-a6-00/0x80 (CML-U 6+2 A0) microcode from revision 0xea
      up to 0xf0;
    • Update of 06-a6-01/0x80 (CML-U 6+2 v2 K1) microcode from revision
      0xec up to 0xf0;
    • Update of 06-a7-01/0x02 (RKL-S B0) microcode from revision 0x50 up
      to 0x53.
1:openssl-1.0.2k-25.el7_9.x86_64 ce-updates
  • Fixes CVE-2022-2078 Infinite loop in BN_mod_sqrt() reachable when parsing certificates
  • Related: rhbz#2067160
openssh-server-7.4p1-22.el7_9.x86_64 ce-updates
  • avoid segfault in Kerberos cache cleanup (#1999263)
  • fix CVE-2021-41617 (#2008884)
libX11-common-1.6.7-4.el7_9.noarch ce-updates
  • Fix CVE-2021-31535 (#1962438)
1:grub2-common-2.02-0.87.0.1.el7.centos. ce-updates
  • Bump for signing
  • Resolves: #1892860
webtop5-zpush-1.3.1-1.ns7.noarch nethserver-updates
  • WebTop 5.17.3 - NethServer/dev#6674
clamav-0.103.7-1.el7.x86_64 epel
  • Update to 0.103.7
webtop5-1.5.6-1.ns7.noarch nethserver-updates
  • WebTop 5.17.5 - NethServer/dev#6684
12:dhcp-libs-4.2.5-83.el7.centos.1.x86_6 ce-updates
  • Wed Jun 9 14:00:00 2021 CentOS Sources bugs@centos.org - 4.2.5-83.el7.centos.1
  • Roll in CentOS Branding
util-linux-2.23.2-65.el7_9.1.x86_64 ce-updates
  • fix #1905956 - RHEL-7: chrt regression: unwanted ‘nice’ value reset on sched_setattr() [rhel-7.9.z]
  • fix #1905954 - RHEL-7: chrt regression: unexpected default scheduler [rhel-7.9.z]
  • fix #1883013 - RHEL-7: chrt command does not support the -R option [rhel-7.9.z]
1:net-snmp-5.7.2-49.el7_9.2.x86_64 ce-updates
  • fix send response: Too long error (#2008696)
32:bind-export-libs-9.11.4-26.P2.el7_9.1 ce-updates
  • Fix memory leak in ECDSA verify processing (CVE-2022-38177)
  • Fix memory leak in EdDSA verify processing (CVE-2022-38178)
systemd-sysv-219-78.el7_9.7.x86_64 ce-updates
  • resolve: introduce reference counting on DnsStream (#2110544)
python-libs-2.7.5-92.el7_9.x86_64 ce-updates
  • Security fix for CVE-2021-3177
    Resolves: rhbz#1918168
nethserver-lsm-1.2.4-1.ns7.noarch nethserver-updates
  • WAN: notification of wan down not sent - Bug NethServer/dev#6497
nethserver-cockpit-1.10.10-1.ns7.noarch nethserver-updates
  • SFTP backup deleted when target is unreachable - Bug NethServer/dev#6658
nethserver-subscription-3.6.8-1.ns7.noar nethserver-updates
  • Subscription: Enable extra repositories inside the subscription - NethServer/dev#6427
rsyslog-8.24.0-57.el7_9.3.x86_64 ce-updates
  • Address CVE-2022-24903, Heap-based overflow in TCP syslog server
    resolves: rhbz#2081395
nethserver-netdata-2.0.2-1.ns7.noarch nethserver-updates
  • netdata update config overwrite - Bug NethServer/dev#6528
restic-0.12.0-1.ns7.x86_64 nethserver-updates
  • Update restic to version 0.12 - NethServer/dev#6436
4:perl-macros-5.16.3-299.el7_9.x86_64 ce-updates
  • Fix CVE-2020-10543 (bug #1839272)
  • Fix CVE-2020-10878 (bug #1839275)
7:lvm2-2.02.187-6.el7_9.5.x86_64 ce-updates
  • Fix fsadm failure due to accessing unbound variable.
  • Fix segfault in vgextend when a PV is missing in the processed VG.
libwebp-0.3.0-10.el7_9.x86_64 ce-updates
  • Added fixes for rhbz#1956829, rhbz#1956843, rhbz#1956919
kpartx-0.4.9-135.el7_9.x86_64 ce-updates
  • Add 0273-RHBZ-1988462-fix-disable-changed-wwids-segfault.patch
  • Resolves: bz #1988462
nethserver-backup-config-2.5.2-1.ns7.noa nethserver-updates
  • Selective file restore not available after rsync-upgrade - Bug NethServer/dev#6522
iscsi-initiator-utils-6.2.0.874-22.el7_9 ce-updates
  • 1946578 fix segfault on case mismatch in config/record file
1:wpa_supplicant-2.6-12.el7_9.2.x86_64 ce-updates
  • P2P: Fix a corner case in peer addition based on PD Request (CVE-2021-27803)
libkadm5-1.15.1-54.el7_9.x86_64 ce-updates
  • Try harder to avoid password change replay errors
  • Resolves: #2063163
kbd-misc-1.15.5-16.el7_9.noarch ce-updates
  • Fix vlock when console or terminal is closed abruptly
    Resolves: #1486233
nethserver-antivirus-1.6.1-1.ns7.noarch nethserver-updates
cyrus-sasl-plain-2.1.26-24.el7_9.x86_64 ce-updates
  • Fix for CVE-2022-24407
  • Resolves: rhbz#2055842
postgresql-server-9.2.24-8.el7_9.x86_64 ce-updates
  • Resolves: CVE-2022-1552
  • Backport upstrem fix: a117cebd638dd02e5c2e791c25e43745f233111b
perl-DBD-Pg-2.19.3-5.el7_9.x86_64 ce-updates
  • Always clear out libpq results before reassigning (rhbz #2020111)
epel-release-7-14.noarch epel
  • Change the baseurl to point to source/tree for srpms
kexec-tools-2.0.15-51.el7_9.3.x86_64 ce-updates
  • Throttle kdump reload request triggered by udev event
python2-distro-1.5.0-1.el7.noarch epel
  • Update to 1.5.0
  • Run tests
  • Cleanup spec
nethserver-httpd-3.12.2-1.ns7.noarch nethserver-updates
  • Set Apache directive AllowEncodedSlashes to NoDecode - NethServer/dev#6559
python2-simplejson-3.11.1-1.el7.x86_64 epel
  • Update to 3.11.1
python2-rsa-3.4.2-3.el7.noarch epel
  • Apply backport patch to fix CVE-2020-25658
gssproxy-0.7.0-30.el7_9.x86_64 ce-updates
  • Always free ciphertext data in gp_encrypt_buffer
  • Resolves: #1887438
1:libuv-1.44.2-1.el7.x86_64 epel
  • Update to libuv 1.44.2
nethserver-fail2ban-1.7.3-1.ns7.noarch nethserver-updates
  • Shorewall doesn’t start after fail2ban install - Bug NethServer/dev#6608
librsync-2.3.2-1.el7.x86_64 epel
  • Upgrade to 2.3.2 (#1948216)
nethserver-nextcloud-1.20.0-1.ns7.noarch nethserver-updates
  • Nextcloud 24.0.5 - NethServer/dev#6696
tzdata-java-2022c-1.el7.noarch ce-updates
  • Rebase to tzdata-2022c - supersedes tzdata-2022b
    • Add a work-around for an awk bug in FreeBSD, macOS, etc.
    • Improve tzselect with respect to intercontinental Zones.
bash-4.2.46-35.el7_9.x86_64 ce-updates
  • Bump version number
    Resolves: #2015565
rsync-3.1.2-11.el7_9.x86_64 ce-updates
  • Resolves: #2111170 - remote arbitrary files write inside the directories of connecting peers
cronie-anacron-1.4.11-24.el7_9.x86_64 ce-updates
webtop5-webdav-1.0.1-1.ns7.noarch nethserver-updates
mdadm-4.1-9.el7_9.x86_64 ce-updates
  • imsm: After reboot put spare devices into right container.
  • Resolves rhbz#2005306
glib2-2.56.1-9.el7_9.x86_64 ce-updates
  • Fix CVE-2021-27219
    Resolves: #1960596
binutils-2.27-44.base.el7_9.1.x86_64 ce-updates
  • Add ability to control the display of unicode characters. (#2009168)
1:nfs-utils-1.3.0-0.68.el7.2.x86_64 ce-updates
  • gssd: mutex updates (bz 1990981)
nspr-4.34.0-3.1.el7_9.x86_64 ce-updates
  • Actually apply the patch in -3
libldb-1.5.4-2.el7.x86_64 ce-updates
  • resolves: #1941511 - Fix CVE-2021-20277
libxml2-2.9.1-6.el7_9.6.x86_64 ce-updates
  • Fix CVE-2016-4658 (#1966916)
nethserver-subscription-inventory-3.6.8- nethserver-updates
1:dmidecode-3.2-5.el7_9.1.x86_64 ce-updates
  • Fix the “OUT OF SPEC” error for empty NVMe and DIMM slots
  • Resolves: rhbz#1858345
clamav-unofficial-sigs-7.2.4-1.el7.noarc epel
  • Thu Mar 18 13:00:00 2021 Ján ONDREJ (SAL) <ondrejj(at)salstar.sk> - 7.2.4-1
  • Update to upstream.
nethserver-restore-data-2.0.7-1.ns7.noar nethserver-updates
  • Restore data: unable to restore file if the path contains a single quote - Bug NethServer/dev#6552
dnsmasq-2.76-17.el7_9.3.x86_64 ce-updates
  • Accept replies from bound sockets again (#1923913)
xz-libs-5.2.2-2.el7_9.x86_64 ce-updates
  • Fix CVE-2022-1271
polkit-0.112-26.el7_9.1.x86_64 ce-updates
  • pkexec: argv overflow results in local privilege esc.
  • Resolves: CVE-2021-4034
nethserver-lang-en-1.4.6-26.ns7.noarch nethserver-updates
  • Automatic release 1.4.6-26
python-firewall-0.6.3-13.el7_9.noarch ce-updates
  • doc: clarify --set-target values “default” vs “reject”
nethserver-sssd-1.7.1-1.ns7.noarch nethserver-updates
  • Failed to add service primaries to system keytab - Bug NethServer/dev#6446
nethserver-diagtools-1.0.4-1.ns7.noarch nethserver-updates
  • get-oui and get-iab cron job doesn’t fetch updates - Bug NethServer/dev#6642
nethserver-backup-data-1.7.6-1.ns7.noarc nethserver-updates
  • restic disaster recovery failure on first run - Bug NethServer/dev#6456
zstd-1.5.2-1.el7.x86_64 epel
  • Latest upstream
perl-Net-Server-2.007-3.el7.noarch epel
  • Bug 1331825 - Add support for IPv6
nethserver-base-3.9.0-1.ns7.noarch nethserver-updates
  • Let’s Encrypt: support short chain - NethServer/dev#6584
sudo-1.8.23-10.el7_9.2.x86_64 ce-updates
  • RHEL 7.9.Z ERRATUM
  • defaults use_pty plus SELinux ROLE in user specification breaks terminal
    Resolves: rhbz#1972820
gtk-update-icon-cache-3.22.30-8.el7_9.x8 ce-updates
  • Further treeview a11y refcount fix (#1965195)
nethserver-unbound-1.1.1-1.ns7.noarch nethserver-updates
  • Unbound: force queries on ipv4 only - NethServer/dev#6526
nethserver-webtop5-1.8.8-1.ns7.noarch nethserver-updates
tuned-2.11.0-12.el7_9.noarch ce-updates
  • disk: added support for the nvme devices
    Resolves: rhbz#1981618
speedtest-cli-2.1.3-1.ns7.noarch nethserver-updates
  • Update to 2.1.3
expat-2.1.0-14.el7_9.x86_64 ce-updates
  • Fix multiple CVEs
  • CVE-2022-25236 expat: namespace-separator characters in “xmlns[:prefix]” attribute values can lead to arbitrary code execution
  • CVE-2022-25235 expat: malformed 2- and 3-byte UTF-8 sequences can lead to arbitrary code execution
  • CVE-2022-25315 expat: integer overflow in storeRawNames()
  • Resolves: CVE-2022-25236
  • Resolves: CVE-2022-25235
  • Resolves: CVE-2022-25315
ImageMagick-6.9.10.68-6.el7_9.x86_64 ce-updates
  • Added fix for rhbz#2005800
rspamd-3.2-1.x86_64 nethserver-updates
  • Update to 1.0.0
14:libpcap-1.5.3-13.el7_9.x86_64 ce-updates
  • Resolves: #2027937 - libpcap 1.5.3 with distro patch applied writes pcap file with broken pkthdr
oniguruma-6.8.2-2.el7.x86_64 epel
  • Backport fix for CVE-2019-13225 from RHEL8, resolves: rhbz#1728967
changelog stats. 253 pkgs, 109 source pkgs, 107 changelogs
I recommend a snapshot/backup before but updating shouldn’t be a problem.
Thank you for respond
The update nexcloud 1.16.4-1 to 1.20.0 is a problem or no?
Thank you
Yes, it is a problem to update 2 major versions, see howto:nextcloud [NethServer Wiki], you need to update step by step.
Scroll down to " Exception: Updates between multiple major versions are unsupported".
Witch is the command for update beacuse i’m not understand wiki
These steps are needed:
yum update nethserver-nextcloud-1.17.1-1.ns7
yum update nethserver-nextcloud-1.18.0-1.ns7
yum update nethserver-nextcloud-1.19.7-1.ns7
The last update should work via Software Center or yum update.
Thank you
tomorrow test solution
Thank you very mutch ambassador
