Info about reverse proxy
NethServer Version: 7
**Module:**reverse proxy
Hi, the module reverse proxy works with mod_security? if no, there is another feature that acts as WAF?
thanks
Andrea
Hi Andrea,
mod_security is not installed.
We don’t even have a WAF (Web Application Firewall) module, no one ever asked for it until now :smiley:
Would you mind to try it on NS and write an howto?
You could start from here: https://devops.profitbricks.com/tutorials/how-to-configure-modsecurity-and-mod_evasive-for-apache-on-centos-7/
ok, i will try this https://www.vultureproject.org/, seems perfect for my scope. The only downside is that it use freesbd.
thanks
Andrea
Hi Andrea;
did you have any success with you’re project of WAF on Nethserver ?
