Improvements for Nethserver-Collabora
here we are, just a noob error, indeed nextcloud knows nothing about my virtualhost that is not resolvable outside, in real situation, a vhos is resolvable by any dns server. SO yes it works.
Think to add a restart to dnsmasq for the default vhost collabora.domain.com
so now what is needed to move to 6.4 ?
Just update the packages, it’s working on some of my servers.
These packages are installed after collabora update:
CODE-brand-6.4-11.noarch
collaboraoffice6.4-6.4.10.27-27.x86_64
collaboraoffice6.4-ure-6.4.10.27-27.x86_64
collaboraofficebasis6.4-calc-6.4.10.27-27.x86_64
collaboraofficebasis6.4-core-6.4.10.27-27.x86_64
collaboraofficebasis6.4-draw-6.4.10.27-27.x86_64
collaboraofficebasis6.4-en-US-6.4.10.27-27.x86_64
collaboraofficebasis6.4-extension-pdf-import-6.4.10.27-27.x86_64
collaboraofficebasis6.4-graphicfilter-6.4.10.27-27.x86_64
collaboraofficebasis6.4-images-6.4.10.27-27.x86_64
collaboraofficebasis6.4-impress-6.4.10.27-27.x86_64
collaboraofficebasis6.4-ooofonts-6.4.10.27-27.x86_64
collaboraofficebasis6.4-ooolinguistic-6.4.10.27-27.x86_64
collaboraofficebasis6.4-writer-6.4.10.27-27.x86_64
loolwsd-6.4.6-6.el7.x86_64
Maybe we could add languages or dictionaries, at least the english one?
collaboraoffice6.4-dict-en.x86_64
yum install yum-utils
yum-config-manager --add-repo https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-centos7
wget https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-centos7/repodata/repomd.xml.key && rpm --import repomd.xml.key
yum update -y
yeah the glitch about the file that it cannot be opened the first time is not here anymore
all :wink:
Total download size: 75 M
Installed size: 306 M
yes en-US and its dictionary, then a doc in the readme, what do you think @mark_nl
Confirmed. Seems the richdocument app was fixed.
Looks good. :grinning:
I installed all dictionary but all languages it is not realizable, about 1.6G
Total download size: 1.6 G
Installed size: 387 M
You’re right, it was just fun. English dictionary is enough and add a hint to the docs as you said.
Who wants to push to nethforge-testing collabora6.4 that people can upgrade
@mark_nl I cannot approve the PR (don’t know why) approved I am OK the readthedoc should also be adjusted.
maybe after this PR you could add the dict en-US with another PR
Done
Done
Done
Have to work tonight, will proceed tomorrow. :wink:
CODE-brand-6.4-11.noarch.rpm
collaboraoffice6.4-6.4.10.28-28.x86_64.rpm
collaboraoffice6.4-dict-en-6.4.10.28-28.x86_64.rpm
collaboraoffice6.4-ure-6.4.10.28-28.x86_64.rpm
collaboraofficebasis6.4-calc-6.4.10.28-28.x86_64.rpm
collaboraofficebasis6.4-core-6.4.10.28-28.x86_64.rpm
collaboraofficebasis6.4-draw-6.4.10.28-28.x86_64.rpm
collaboraofficebasis6.4-en-US-6.4.10.28-28.x86_64.rpm
collaboraofficebasis6.4-extension-pdf-import-6.4.10.28-28.x86_64.rpm
collaboraofficebasis6.4-graphicfilter-6.4.10.28-28.x86_64.rpm
collaboraofficebasis6.4-images-6.4.10.28-28.x86_64.rpm
collaboraofficebasis6.4-impress-6.4.10.28-28.x86_64.rpm
collaboraofficebasis6.4-ooofonts-6.4.10.28-28.x86_64.rpm
collaboraofficebasis6.4-ooolinguistic-6.4.10.28-28.x86_64.rpm
collaboraofficebasis6.4-writer-6.4.10.28-28.x86_64.rpm
loolwsd-6.4.6-8.el7.x86_64.rpm
* Mon Aug 03 2015 Mihai Varga
- added the cronjob
pushed to nethforge testing, we should add the en dictionnary
hum something broken with the PR of @mark_nl, the upgrade is not smooth
Apr 15 17:00:21 ns7loc10 esmith::event[9526]: Failed to activate any config changes
Apr 15 17:00:21 ns7loc10 esmith::event[9526]: Server error: `GET https://collabora.nethservertest.org/hosting/discovery` resulted in a `503 Service Unavailable` response:
Apr 15 17:00:21 ns7loc10 esmith::event[9526]: <!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
Apr 15 17:00:21 ns7loc10 esmith::event[9526]: <html><head>
Apr 15 17:00:21 ns7loc10 esmith::event[9526]: <title>503 Service Unavailable</title>
Apr 15 17:00:21 ns7loc10 esmith::event[9526]: </head><body>
Apr 15 17:00:21 ns7loc10 esmith::event[9526]: <h1 (truncated...)
Apr 15 17:00:21 ns7loc10 esmith::event[9526]: Action: /etc/e-smith/events/nethserver-collabora-update/S91nethserver-collabora-set-wopi-url FAILED: 1 [1.663464]
Apr 15 17:00:21 ns7loc10 esmith::event[9526]: Event: nethserver-collabora-update FAILED
This is done because the action is triggered after the loolwsd service restart, I I launch the action before the service start I have no errors.
This sounds me something :-?
Continue the work of Mark, I need your tests
The main job is that you can use non trusted certificates and the vhost collabora.domain.com is created automatically
Thanx :+1:
Late to the party, will do some tests soon
You are back
 I was worried about :slight_smile:
_ OT _
Well had a hard time, but it worked out good.
Will attend to my nethserver “duties” as much as I can.
Still have to attend to this :astonished: , ATM distracted by:
a) getting Rocky Linux running on aarch64 devices
b) rebuilding (scl) rh-mariadb105 on armv7hl
c) ns8-scratchpad
