It should be possible to add additional settings for virtual hosts in a seperate new field the UI, especially ws:// proxy statements. Currently this is not possible and the reverse proxy UI cannot be used at all. This has several disadvantages:
- No easy UI configuration, instead complicated configuration via file
- No overview in the UI over the configured reverse proxy settings and virtual hosts
- Missing entries in the hosts for local access
E.g.: For Webtop reverse proxy to , you need four lines:
ProxyPass /webtop/push ws://192.168.77.20/webtop/push
ProxyPassReverse /webtop/push ws://192.168.77.20/webtop/push
ProxyPass / https://192.168.77.20/ max=3 retry=30
ProxyPassReverse / https://192.168.77.20/
But only the latter two are generated from the virtual hosts settings via UI.
Improvement:
It should be possible to add the missing first two manul settings into a separate entry field. These additional settings should be included BEFORE the standard proxypass settings (because of the apache matching rules).
