[lsd@leo nethserver-transmission]$ tx push -s
File "/usr/bin/tx", line 9, in <module>
load_entry_point('transifex-client==0.12.2', 'console_scripts', 'tx')()
File "/usr/lib/python2.7/site-packages/pkg_resources/__init__.py", line 563, in load_entry_point
return get_distribution(dist).load_entry_point(group, name)
File "/usr/lib/python2.7/site-packages/pkg_resources/__init__.py", line 2651, in load_entry_point
return ep.load()
File "/usr/lib/python2.7/site-packages/pkg_resources/__init__.py", line 2305, in load
return self.resolve()
File "/usr/lib/python2.7/site-packages/pkg_resources/__init__.py", line 2311, in resolve
module = __import__(self.module_name, fromlist=['__name__'], level=0)
File "/usr/lib/python2.7/site-packages/txclib/cmdline.py", line 7, in <module>
from urllib3.exceptions import SSLError
File "/usr/lib/python2.7/site-packages/urllib3/__init__.py", line 8, in <module>
from .connectionpool import (
File "/usr/lib/python2.7/site-packages/urllib3/connectionpool.py", line 29, in <module>
from .connection import (
File "/usr/lib/python2.7/site-packages/urllib3/connection.py", line 39, in <module>
from .util.ssl_ import (
ImportError: No module named util.ssl_
when I do : tx push -s
I have some python errors. I use Fedora 26…someone have a trick @dev_team ???
ok some errors more…I will look after the documentation : tx --help crash
[lsd@leo nethserver-diagtools]$ tx --help
return ep.load()
[root@leo lsd]# tx --help
Usage: tx [options] command [cmd_options]
This is the Transifex command line client which allows you to manage your
translations locally and sync them with the master Transifex server. If you'd
like to check the available commands issue `tx help` or if you just want help
with a specific command issue `tx help command`
Options:
--version show program's version number and exit
-h, --help show this help message and exit
-d, --debug enable debug messages
-q, --quiet don't print status messages to stdout
-r ROOT_DIR, --root=ROOT_DIR
change root directory (default is cwd)
--traceback print full traceback on exceptions
--disable-colors disable colors in the output of commands
