Important security improvements for NethServer
We are pleased to announce that 4 weeks ago we released new updates for NethServer 8, introducing important fixes and significant hardening designed to further reduce the system’s attack surface.
Upcoming Security Bulletin
Transparency is a core value of our project. On April 14th, we will publish a detailed Security Bulletin regarding these improvements.
Context & Perimeter
These updates are the result of a private penetration test performed on a specific installation of the NethSecurity Controller.
  • Proactive Fixes: During this assessment, a potential vulnerability was identified. We have successfully patched this flaw before any exploitation could occur.
  • Core Hardening: We took this opportunity to go beyond the specific finding, implementing a broader hardening of the NethServer 8 Core to strengthen the foundation of the entire ecosystem.
  • No Security Incidents: We want to clearly reassure our community that no incidents or breaches have occurred. These measures are entirely proactive.
The upcoming bulletin will clearly define the scope of the testing and the logic behind the fixes. We have carefully evaluated the information being shared; we believe that providing this clarity does not grant an advantage to potential attackers. Instead, it empowers our users with the knowledge needed to maintain a secure environment.
Minimum versions and verification
If automatic updates are enabled, systems are already protected. Below are the references to manually verify installed versions.
To be protected, ensure you are running the following versions (released starting from February 27, 2026) or later:
  • core: 3.18.3
  • nethsecurity-controller: 2.1.6
  • metrics: 1.2.4
How to check:
Go to the Applications page and filter by name to view module versions.
The core version of each node is visible by clicking the Core applications button.
How to update
Updates can be managed from the Software Center, more details in the manual
Hi Alessio ! Do you have more info ? Was this breach actively exploited ?
The security issue was found during an audit done by a partner.
We will publish the relevant security bulletins in 7-10 days.
As far as we know, the breach has never been exploited.
A penetration test has found a weakness that has been fixed.
No breaches or incidents have been reported.
Please wait for the security bulletins for all the details.
Thanks for the heads up, I do not see nethsecurity-controller being part of the core applications?
ps. Taking another look at core applications, it seems that some modules that can be installed, are becoming part of core applications if they are installed. Maybe it is just me, but I always thought that core applications are only the applications that are installed at initial installation time to run a basic NS8 server. So now the ‘basic’ core set of applications may vary from system to system. Is that not confusing? (feel free to split my remarks into a seperate topic).
It’s not, it’s an application that can be installed.
Indeed, hence my remarks above. NS8 Core applications can be a dynamic set and not a fixed set, where I thought that the core applications is a fixed and essential set of a basic NS8 server. All other apps that can be installed via software center are apps/modules, not part of the fixed core set.
Yes, that’s correct, thank you for pointing it out. I’ve updated and clarified the relevant section accordingly: https://docs.nethserver.org/projects/ns8/en/latest/software_center.html#core-updates
Security advisories:
I don’t get if the workarounds for
  • Temporary support password visible inside logs
  • Metrics: Grafana accessible with default credentials on localhost
are obsolete when patched version is installed or still need to be applied.
No workaround for it, you need to update the package.
In this case a workaround could be change manually the Grafana config, but the updated module does it automatically.
The workaround are useless when the packages are updated. They can be applied only if you do not want to update the system.
Thanks for taking the time to answer.
