Windows Server Version: 2022
Module: imapsync and mail
I cannot setup Imapsync if NS8 is joined to external LDAP…
Shouldn’t this be possible?
Imapsync is designed to use the ns8 mail server you have to link imasync to it
Remove and reinstall imasync but before try to check the cli below
I did a quick test with a remote LDAP and no pb so far ![]()
[root@R4-pve ~]# tree /home/imapsync1/.config/state/
/home/imapsync2/.config/state/
├── CACHEDIR.TAG
├── agent.env
├── apitoken.cache
├── cron
├── environment
└── imapsync
├── stephane_9bevc3.env
├── stephane_9bevc3.pwd
└── vmail.pwd
[root@R4-pve ~]# cat /home/imapsync1/.config/state/imapsync/vmail.pwd
yrG@S..xiB%K@O/+G,g5/RplJMvZPnVa
please did you configure the ldap with the toggle verify the tls certificate to true ???
you can browse users in the ldap page and in the maiboxes of the mail page ?
so to resume, you joined a remote domain without TLS, you got no error so far from the UI, but obviously you cannot list the users of the domain, does it sound close of your issue ?
The 1. Test without TLS and TLS verification did not work as expected.
The 2. Test, as you can see in the screenshot, works so far. I can list users etc., but I have to do forther tests to be sure mails are fetched from the provider and sorted to the users and sent out correctly…
question, do you think that an AD allowing to authenticate without TLS remotely is safe enough !!!
maybe dovecot forces the TLS on its own
cc @davidep
No
It looks like…
tested on a remote ldap account without TLS, I cannot reproduce the issue
create an AD on NS7
set to do not ask for encryption
bind to this AD on NS8 without TLS on port 389
install mail, webtop, imapsync
I can use the domain page and the mailboxes page, and the imapsync page, I can login with ldap users to webtop
If I remove the custom template I did on NS7 and I restart the nsdc, then I cannot browse remotely the users on all pages
