Imapsync automatic synchronization problem
Module: imapsync v1.2.7
Hi all, the automatic sync.task in imapsync no longer works after upgrading from Debian 12 to Debian 13.
While it is still possible to fetch mail manually, the automatic synchronization no longer functions…
We need logs to understand because the cron is inside the container not in debian 13 so it should not happen
I made a backup (Debian 13) and restored the mail relay back to Debian 12 so that I can continue working as usual. I will restore the backup to a new VM over the weekend and continue from there.
