IMAP seemed to stop working
I thought iIwas on final:
System version
NethServer release 7.6.1810 (final)
Kernel release
3.10.0-862.14.4.el7.x86_64
I do have a notice that said: A new upstream distribution release 7.6 is available as update. Should I unlock and install this? Do I need to undo the console commands I did earlier to get email working so the anti-spam(?) works again?
Please remove the custom template files.
This should not be necessary.
I’m sorry, but I don’t understand removing the custom template files. Did I install custom templates when you suggested the command line stuff to fix my issue? You’ll have to excuse my ignorance.
Yes, the files you created in /etc/e-smith/templates-custom. Custom templates are used to override the default configuration templates.
http://docs.nethserver.org/projects/nethserver-devel/en/v7/templates.html#local-site-overrides-templates-custom-and-templates-user-custom
