Image Running on Banana Pi M2 Ultra
NethServer Version: 7.6
I want to setup a banana pi m2u, but the raspberry pi image doesn’t work. Only red LED. Also tried an Ubuntu image for bpi m2u, this works.
It’s my first arm and I don’t know anything about installing it, can somebody give me tips, what I have to do to install nethserver? Here is a short overview of the Hardware:
http://wiki.banana-pi.org/Banana_Pi_BPI-M2U#Hardware_spec
Thanks in advance Michael.
AFAIK Raspberry Pi uses BCM SoC. Banana Pi use… another kind of SoC (Allwinner R40/V40).
End of the game…
I found a centos image for the banana pi.
After starting up centos you may try to install nethserver arm:
yum install http://mirror.nethserver.org/nethserver/7.6.1810/arm-base/armhfp/Packages/nethserver-release-7-11.ns7.noarch.rpm
And like described in the install docs or in the wiki:
nethserver-install
It’s an older image and I never tested it (no hardware) but it should be a good starting point.
Thanks, I will try this. Will be back with a result next days.
Hi Markus,
tested an image from
this works, my next step is installing nethserver on it.
Nethserver is running on banana pi m2 ultra
I only wonder that it only shows a 6,67 GB root partition. I’ve put the CentOS Image to a 64 GB SD-Card and after booting CentOS from SD-Card I installed nethserver.
55
Great that it works!
Just execute following command to use the whole space:
rootfs-expand
Thanks Markus, I had to install cloud-utils-growpart before, but after that it runs perfectly.
