NethServer Version: 7.7
Module: Mariadb
I installed phpmyadmin, but I can not login, followed the steps of the site: https://wiki.nethserver.org/doku.php?id=phpmyadmin, unsuccessfully it is installed but I can not login with any user.
Module: Mariadb
Hi, Alessandro.
user is admin. The password can be found using the command indicated in the guide:
cat /root/.my.cnf
I get the password there but no access, already tried the browser, terminal, local and remote and does not access.
Do you get access to phpmyadmin login page?
config show phpmyadmin
I don’t have, I don’t know why.
You can check /var/log/messages and /var/log/yum to get some clues about what was installed and what happened.
You can try to create an administrator user and login with him:
mysql
GRANT ALL PRIVILEGES ON *.* TO 'administrator'@'localhost' IDENTIFIED BY 'yourpassword';
\q
Try to login to phpmyadmin with administrator user.
Give us feedback.
rpm -qa | grep -i 'phpmyadmin'
please what is the output
Simple you missed to install my rpm
Nethserver-phpmyadmin
Sorry me more I did not understand !!
yum install http://mirror.de-labrusse.fr/NethServer/7/x86_64/nethserver-stephdl-1.0.8-1.ns7.sdl.noarch.rpm
yum install nethserver-phpmyadmin
Thanks for the reply, resolved here.
