Howto manage or customize NS8 podman containers
This is a first draft of a container customization howto. Due to Podman, troubleshooting or customizations need to be done inside app environments and containers which I’d like to explain in this howto.
Podman in NS8
Introduction
Podman provides rootless containers which are running as user. Most NS8 apps make use of these rootless containers.
Those apps are located in /home/ like linux users whereas rootfull apps are located in /var/lib/nethserver.
Information about specific app customizations can be found on the GitHub page of the app, see for example SOGo.
App Environment
To enter a rootless app environment, you can use the runagent command, see Rootless vs Rootfull | NS8 dev manual
runagent -m app1
It’s also possible to append a command. In this case the command is executed in the app environment but you don’t enter it:
runagent -m app1 command
To list the running containers and their names you could use podman ps. As root you’ll see the rootfull containers, in an app environment you’ll see the containers of the rootless app.
podman ps
With podman the containers are started via systemd, a container is a service. To stop or (re)start a container or get the status you could use systemctl, see https://community.nethserver.org/t/ns8-starting-stopping-apps/23231:
If the podman containers are not running you can list all the services available in an app instance environment:
runagent -m appname1 ls -lisa /home/appname1/.config/systemd/user
Stop and Start Containers
At Any Given Time, we might have a need to stop a running container.
We would achieve this By Running (from inside the app’s environment)
systemctl --user stop containername
systemctl --user start containername
systemctl --user restart containername
systemctl --user status containername
Or restart an app as root:
systemctl restart user@$(id -u app1).service
For example restart app instance webserver1:
systemctl restart user@$(id -u webserver1).service
To run a command in the container or to enter the container you could use podman exec, see podman-exec — Podman documentation
podman exec -ti containername command
If the command is a shell you’ll enter the container, for example
podman exec -ti dovecot sh
Data and volumes
In containers the data is saved in volumes. To manage volumes you could use podman volume, see podman-volume — Podman documentation
To list the volumes:
podman volume ls
To remove a volume:
podman volume rm volumename
To remove all volumes:
podman volume rm -a
The volumes of rootless containers of app1 are located in /home/app1/.local/share/containers/storage/volumes/
Local and container users and permissions
Usually the local app1 user is the root user in the container.
In the following example the local user roundcubemail3 is root in the container:
[root@ns8rockytest ~]# ls -l /home/roundcubemail3/.local/share/containers/storage/volumes/html/_data/
total 372
-rw-r--r--.  1 roundcubemail3 roundcubemail3 216244 Feb  8 09:47 CHANGELOG.md
-rw-r--r--.  1 roundcubemail3 roundcubemail3  12714 Feb  8 09:47 INSTALL
-rw-r--r--.  1 roundcubemail3 roundcubemail3  35147 Feb  8 09:47 LICENSE
-rw-r--r--.  1 roundcubemail3 roundcubemail3   3853 Feb  8 09:47 README.md
-rw-r--r--.  1 roundcubemail3 roundcubemail3   1049 Feb  8 09:47 SECURITY.md
drwxr-xr-x.  7 roundcubemail3 roundcubemail3   4096 Feb  8 09:47 SQL
-rw-r--r--.  1 roundcubemail3 roundcubemail3   4657 Feb  8 09:47 UPGRADING
drwxr-xr-x.  2 roundcubemail3 roundcubemail3   4096 Feb  8 09:47 bin
-rw-r--r--.  1 roundcubemail3 roundcubemail3    993 Jun 11 11:18 composer.json
-rw-r--r--.  1 roundcubemail3 roundcubemail3   1086 Feb  8 09:47 composer.json-dist
-rw-r--r--.  1 roundcubemail3 roundcubemail3  56747 May 26 09:31 composer.lock
drwxr-xr-x.  2 roundcubemail3 roundcubemail3    148 Apr 29 12:00 config
-rw-r--r--.  1 roundcubemail3 roundcubemail3  11200 Feb  8 09:47 index.php
drwxr-xr-x.  2         886464         886464     23 Feb  8 09:47 logs
drwxr-xr-x. 37 roundcubemail3 roundcubemail3   4096 Feb  8 09:47 plugins
drwxr-xr-x.  8 roundcubemail3 roundcubemail3     94 Feb  8 09:47 program
drwxr-xr-x.  3 roundcubemail3 roundcubemail3     83 Feb  8 09:47 public_html
drwxr-xr-x.  3 roundcubemail3 roundcubemail3     21 Feb  8 09:47 skins
drwxr-xr-x.  2 roundcubemail3 roundcubemail3     23 Feb  8 09:47 temp
drwxr-xr-x. 14 roundcubemail3 roundcubemail3   4096 May 26 09:31 vendor
[root@ns8rockytest ~]# runagent -m roundcubemail3 podman exec roundcubemail-app ls -l
total 372
-rw-r--r--.  1 root     root     216244 Feb  8 08:47 CHANGELOG.md
-rw-r--r--.  1 root     root      12714 Feb  8 08:47 INSTALL
-rw-r--r--.  1 root     root      35147 Feb  8 08:47 LICENSE
-rw-r--r--.  1 root     root       3853 Feb  8 08:47 README.md
-rw-r--r--.  1 root     root       1049 Feb  8 08:47 SECURITY.md
drwxr-xr-x.  7 root     root       4096 Feb  8 08:47 SQL
-rw-r--r--.  1 root     root       4657 Feb  8 08:47 UPGRADING
drwxr-xr-x.  2 root     root       4096 Feb  8 08:47 bin
-rw-r--r--.  1 root     root        993 Jun 11 09:18 composer.json
-rw-r--r--.  1 root     root       1086 Feb  8 08:47 composer.json-dist
-rw-r--r--.  1 root     root      56747 May 26 07:31 composer.lock
drwxr-xr-x.  2 root     root        148 Apr 29 10:00 config
-rw-r--r--.  1 root     root      11200 Feb  8 08:47 index.php
drwxr-xr-x.  2 www-data www-data     23 Feb  8 08:47 logs
drwxr-xr-x. 37 root     root       4096 Feb  8 08:47 plugins
drwxr-xr-x.  8 root     root         94 Feb  8 08:47 program
drwxr-xr-x.  3 root     root         83 Feb  8 08:47 public_html
drwxr-xr-x.  3 root     root         21 Feb  8 08:47 skins
drwxr-xr-x.  2 root     root         23 Feb  8 08:47 temp
drwxr-xr-x. 14 root     root       4096 May 26 07:31 vendor
If a user doesn’t exist locally you’ll just see the UID and GID instead of a name like for the logs directory which is owned by www-data in the container but local it has a UID/GID of 886464.
Software installation in containers
It’s possible to install packages in the containers, this could be needed for troubleshooting or to test implementing new features. Installed packages are not persistent, after restarting the container they’re not kept.
Most containers are Debian/Ubuntu or Alpine based so you could use apk (Alpine) or apt (Ubuntu/Debian) to install packages.
Debian/Ubuntu:
apt update
apt install packages
Alpine:
apk add package
Now this should be promoted to the official documentation ! I missed this so much !
To list all the services available in a container :
runagent -m appname ls -a / /home/appname/.config/systemd/user
Thanks, I added it to the howto. It’s wikified so it should be possible for everyone to edit it and add missing stuff.
can’t find it ?
It’s before “Stop and Start Containers”:
I mean the wiki ?
Sorry, with “wikified” I meant that everybody can edit this howto here in the community forum.
I’m not sure if it’s already good enough to put it to wiki.nethserver.org.
Oh great didn’t know it was possible
I’ve got my eye on it :wink: For now there is a link on the wiki. Thanks!
How can I get a list of the memory usage of each module/app/container?
Memory and Storage, That’s Necessary to have on the UI, however i think the integrated grafana Dashboard might have this info?
Where are environment variables stored? And how do I change them? I’m trying to change PHP_UPLOAD_LIMIT in my Nextcloud module.
Asnwered by @mrmarkuz your other question.
