How would you build your ideal Nethserver for personal use?
As this is partially fantasy, do not limit yourself purely by cost but at the same time dont go nuts with super expensive stuff. Do consider your own personal needs/environment.
I am mostly interested in the hardware you would use, but the additional packages/programs would be of interest too.
For me I would mostly be looking at a server capable of running a few VM’s. Id like an AD DC server/VM, possibly separate from a file server VM and then likely a Dev server VM and some dev client VM’s.
I am looking at something like:
Supermicro 5028D-TN4T
Ideally based on the newer board/CPU like:
Supermicro X11SDV-8C-TLN2F
I am also eagerly awaiting the release and availability of the AMD Epyc 3000 series SoC’s as they should give good performance at a much lower price point (the 8c/16t is rumored to be roughly $400).
If possible Id like to keep using my Fractal Design Node 304 case as its perfect for a home lab/server with 6x 3.5" bays using an ITX board but still small enough and quite enough to fit in my entertainment center in the living room.
I have also considered building my own (again) but its hard to find any decent ITX board for recent CPU’s available in 8c/16t.
I currently have 4x 4TB drives which I would likely start to replace with 8TB drives as the cost has come down.
Presumably I could use the PCIe slot on the ITX for a quad nvme card as well. Id likely run my VM’s from this storage, maybe slice off a small chuck and set aside for more demanding applications too. Id then use the HDD’s in a pool for file storage.
All in all I think with a budget of around $2,000 it would be possible to build something ITX, 8c/16t, 32GB+ RAM, 4 or more 8TB drives. Likely not including SSD’s in the budget or maybe just 1 as OS/VM drive to start.
Software wise not sure if there is anything outside the typical well known modules for Nethserver I would use.
