Hi folks,
This “How To” is about get access to the one of common DarkNet (https://geti2p.net) protocols and not overload your NS (NS performance and system requirments)which is distributed on CentOS but without any kernel tuning.
I’m shearing this because maybe some of you like to have I2P router over the world and access this protocol.
I also don’t like Vim to much so I will edit with Nano. I will install Monitorix (https://www.monitorix.org/) just to get full picture how our router is doing.
CentOS don’t have actually net-tools in minimal.iso so we will install this also just to have netstat in Monitorix.
I will go in short so just steps to do and nothing more
You will have after all of this I2P router,and Monitorix on your local LAN and not overkilled your NS. Just you need forward ports to your I2P from NS.
Let’s be professional in this new net -> DarkNet users so I recommend that you install IPS module from NS so you can track/block what you don’t like. (just don’t be mad about policies because you can kill your NS box and don’t get accurate data. Use “SCAN” policy for start. You will see how honest and clean DarkNet is and you not overload your NS server).
OK.
Let’s start do it.
Environment - VM
I recommend don’t do it on your local machine.
Let’s do it in VM box because this is just router to I2P and this manual will work for both local and VM installation but my recommendation is don’t do it locally.
In this days we can have virtualised host for cheap so here we will do that on the VM which is connected to Your LAN and behind your NS gateway.
I2P box <- VM box you can do it from your WebVirtMgr which is not supported by NS any more but this is because development die there. You can still tune your NS with this -> https://github.com/retspen/webvirtcloud
1 core
1G Ram
256M boot
512M swap - just in case how much you planning be active in DarkNet. If just for browsing or email you can ignore it.
3G disc
yum update
yum install nano wget java-1.8.0-openjdk https://dl.fedoraproject.org/pub/epel/epel-release-latest-7.noarch.rpm net-tools
yum install monitorix
systemctl enable monitorix
systemctl start monitorix
nano /etc/monitorix/monitorix.conf
# Monitorix - configuration file
# See monitorix.conf(5) manpage for a detailed description of each option.
title = i2p router <- name it so is the name in your browser
hostname = i2p.yourlocaldomain.local <- do it if you have local DNS / just handy to quickly access the statistics
systemctl disable firewalld <- just do it if you are in your LAN and forward tcp/udp port designed for your I2P router
Let’s tune a bit our VM box
sudo nano /etc/sysctl.conf
vm.swappiness = 10
vm.vfs_cache_pressure = 50
Install your cert just to not login over ssh plain text (but we are still in LAN of course :-) )
mkdir .ssh
chmod 700 .ssh
nano .ssh/authorized_keys -> your generated id_rsa.pub copy and paste here
chmod 600 .ssh/authorized_keys
wget (java version you prefer but read this -> https://geti2p.net/en/download)
export JAVA_HOME=/usr/lib/jvm/your download/jre
java -jar i2p.jar -console
edit -> /root/.i2p/clients.config (Let’s do this router accessible from any client on your LAN this is why I’m root in this manual and keep it clean. This is just our gateway for your browser nothing more.)
change -> clientApp.0.args=7657 0.0.0.0 ./webapps/
edit -> nano i2prouter <- you like to be root
ALLOW_ROOT=true
reboot <- I prefer this after all my installations.
sh i2prouter start (of course you are in the same directory)
Welcome in DarkNet without going mad about performance for both networks.
You will not overkill NS gateway and you will have I2P network working.
If you planning torrents, etc through this gateway you are just another scriptkido in my opinion.
Any question will be answered :-)
i2prouter tuning
bandwidth - 200 IN/OUT ;50% sharing <- my recommendations on start/ you need to know who is your privilege clearnet/darknet
I will implemented emby server also anyone like to have “How To” about it because if not then I do not keep going with this section of NS.
Sorry for this bold but I just copy and paste
