Hi Team,
I would like to ask for you expertise the proper way to use the traffic shaper. I tried this:
But I am not sure if it is working or not. How will I know it? Thanks.
Regards,
Eliezer Ga
Hi Team,
Regards,
Eliezer Ga
You can try sites like this: http://testmy.net/ and post here upload test results
Test it from different hosts
Will do. Thank you for your help.
How about speedtest.net? You can play with bandwith and make measures each time.
