NethServer Version: 7
Module: ClamAV
ClamAV seams to only being used by rSpamD and I thought I would be able to program a scan for my files too (like it is possible with OpenMediaVault).
- Did I understood properly ?
Using clamscan via the console I was wondering if…
I have to specify the database and if yes where is the database
clamscan -d /$PATH/$DATABASE -r /var/lib/nethserver/ibay -
I’m currently running this command but detect-broken is skipped
clamscan --detect-pua=yes --detect-structured=yes --detect-broken=yes -r -l /home/clamscan.log /var/lib/nethserver/ibay/
Does someones have
- an idea why detect-broken is skipped ?
- a better set of option to suggest ?
I’m all ears here
