How to remove CUPS ?
I have install cups to see few things.
After seeing what I want to see, I want to remove Cups…
In the Softare Center, I click on remove…
in the log, I can see
In the Software Center, Cups and Avahi are in the Availables app.
In the CLI, I can restart the avahi-daemon service…
In the CLI, I done yum remove cups… And It`s still here…
The Network Services page displays all registered services.
If the package is uninstalled, ports are still open.
If you want, you must remove the record manually:
config delete <service_name>
There is no easy way to safely remove the configuration after the uninstall process.
