NethServer Version: 7.3.2003
Module: Base
My users are really, really bad. How can I entirely remove the option of 2FA from the server?
Module: Base
Each user stores the key inside his home
rm -f /var/lib/nethserver/home/*/.2fa.secret
signal-event otp-save
https://docs.nethserver.org/en/latest/base_system2.html?highlight=otp#emergency-recovery
Hum…this has not been taken into account…each is free to use or not. We have not thought on it.
For those who use it, you can make a cron to remove the key each night
Ok. My users are incredibly poor on this and I’d rather NOT have the section show at all.
Thanks for the reply.
Sorry, but there isn’t an option to hide that part.
To enable 2FA you need the validation step, poor users should not be able to complete it.
If they enable it, for sure they will be able to use it.
