How to let MS AD Users change their passwords with NethServer?
NethServer Version: NethServer release 7.5.1804 (final)
Hi community!
I’ve been recently taking a look at NethServer to run a vast variety of application services for my home-lab/business and so far, its great! However, I have one big snag keeping it from 100%:
  • I have spent nearly 2 weeks attempting to figure out how to let Microsoft AD users change their passwords by themselves.
I’ve done all sorts of Google-fu + searching on this forum in attempts to find a solution to no avail. I know NextCloud has the ability to support this feature, but it appears bugged and always states “Wrong password” when attempting to change.
If anyone can provide some guidance so I can stop beating my head against a brick wall, I’d highly appreciate it.
Users may login to server manager or change it with Windows.
http://docs.nethserver.org/en/v7/accounts.html#changing-the-password
Thanks for the quick response mrmarkuz
In my many search attempts, I found this information and tested it. However, on my test account (which is managed under MS AD), the button appears to be MIA:
Crazy, it should look like this:
grafik
You may try another browser or check the browser debugger for errors. Do you have same issue with the root user?
Unforunately, that is not the case.
I just tested it again on Firefox, Chrome, Opera, Internet Explorer 11 (both Windows 10 + Windows Server 2016 Standard), Edge (both Windows 10 and on Android), Safari on Mobile, Firefox on Android, Chrome on Android, and still nothing.
Could I have a configuration issue on my AD? I will say I am a bit new to AD, but beyond being able to change my password everything else is working as expected.
You may check /var/log/messages for Nethgui or other errors.
What if you change your password from Windows 10? Does that work?
If it’s just a test machine you may try to uninstall and reinstall AD.
Unfortunately, I couldn’t find any relevant information that seemed useful to me in those logs. I’ve included a link which contains the full log, but yeah …
I can change my password on Windows, and on my Domain-Joined Laptop. Still no Change Password button on NethServer WebGUI.
logs.txt:
https://cdn.discordapp.com/attachments/227982932822851585/464118380459327491/logs.txt
If I recall correctly, when NethServer is bound to a remote account provider (remote AD / Microsoft AD) the access is read-only.
OMG, thanks @dnutan
@Reinitialized, sorry, I assumed you are using a local account provider
