How to join a Linux-Desktop to NS7 Active Directory with realmd?
Hi Thomas, no problems at all, atm :smile:
I tried to join debian 9 Client and it has been working too. I use this little quick and dirty script for it:
#! /bin/sh
DOMAIN=$(realm discover | grep domain-name: | awk '{print $2}')
apt-get install sudo
sudo apt-get -y install realmd
sudo apt-get -y install ntp adcli sssd
sudo mkdir -p /var/lib/samba/private
sudo systemctl enable sssd
clear
echo ""
sudo realm discover $DOMAIN
echo ""
sudo realm join --user=administrator $DOMAIN
sudo systemctl start sssd
echo "session required pam_mkhomedir.so skel=/etc/skel/ umask=0022" | sudo tee -a /etc/pam.d/common-session
sudo apt-get install libsss-sudo
echo "administrator@$DOMAIN ALL=(ALL) ALL" | sudo tee -a /etc/sudoers.d/DomainAdmins
echo "admin@$DOMAIN ALL=(ALL) ALL" | sudo tee -a /etc/sudoers.d/DomainAdmins
clear
echo ""
echo "     Please reboot your Machine !!! - Logon with administrator@$DOMAIN after reboot"
exit 0
Yes, I hit the same on my Fedora, so I added the following lines under the id_provider one:
override_homedir = /home/%u@%d
override_shell = /bin/bash
Furthermore the authentication recently stopped working (I do not use domain accounts every day…). In sssd journal found
 [sssd[krb5_child[3013]]][3013]: Encryption type not permitted
To workaround kerberos issues with encryption algorithms, I set the LEGACY policy in /etc/crypto-policies/config as follow:
# This file should contain a single keyword, the crypto policy to
# be applied by default to applications. The available policies are
# restricted to the following profiles.
# * LEGACY: ensures maximum compatibility with legacy systems (64-bit
#   security)
# * DEFAULT: A reasonable default for today's standards (80-bit security).
# * FUTURE: A level that will provide security on a conservative level that is
#   believed to withstand any near-term future attacks (128-bit security).
# After modifying this file, you need to run update-crypto-policies
# for the changes to propagate.
LEGACY
OK, thank you davide ! I will test it next time…
Yep, looks good… I am able to logon with admin@example.org too :grin:
Last thing (I hope), I don’t get a shell for user admin@example.org:
Do you know how to get a shell for the “normal” users ?
Updated my previous post: override_shell
Excellent !!! - Thank you very much…
±±+ join fedora Client to NethServer 7 AD v01 ±±+
On fedora 27 Desktop !
get root:
sudo su
install some packages:
yum install nano openssh-server realmd oddjob oddjob-mkhomedir sssd adcli samba-common
start and enable ssh-server:
systemctl start sshd
systemctl enable sshd.service
change from DEFAULT to LEGACY:
nano /etc/crypto-policies/config
LEGACY
join domain:
realm join --user=administrator example.org
check domain-join with:
id administrator@example.org
add override_homedir and override_shell, on the end:
nano /etc/sssd/sssd.conf
set sudoers permission
echo “administrator@example.org ALL=(ALL) ALL” | sudo tee -a /etc/sudoers
echo “admin@example.org ALL=(ALL) ALL” | sudo tee -a /etc/sudoers
reboot fedora:
reboot
after reboot, logon with:
user: administrator@example.org
pass: your-administrator-password
Please share the solution in a new topic with #howto category :blush:
OK… :relaxed:
