How-to-install PWM-Password-Management with Nethserver
v7
(Zwordi) #1
Openldap
PWM install relay on memberOf attribute which is not activate by default with Nethserver.
You need to load the module «memberof.la» into the LDAP.
You don’t have to worry much as you already got all you need on your local Nethserver.
The only thing you have to do is to activate it by command-line
dn: cn=module{1},cn=config
changetype: modify
add: olcModuleLoad
olcModuleLoad: memberof.la
Then use the command to load this module into your LDAP.
ldapmodify -Y EXTERNAL <<EOF
changetype: modify
add: olcModuleLoad
add: olcModuleLoad
olcModuleLoad: refint
> EOF
SASL/EXTERNAL authentication started
SASL username: gidNumber=0+uidNumber=0,cn=peercred,cn=external,cn=auth
SASL SSF: 0
modifying entry "cn=module{1},cn=config"
Then we need to configure this module with two files :
Files memberofmodule.ldiff
dn: olcOverlay={0}memberof,olcDatabase={2}hdb,cn=config
objectClass: olcConfig
objectClass: olcMemberOf
objectClass: olcOverlayConfig
objectClass: top
olcOverlay: memberof
olcMemberOfDangling: ignore
olcMemberOfRefInt: TRUE
olcMemberOfGroupOC: groupOfNames
olcMemberOfMemberAD: member
olcMemberOfMemberOfAD: memberOf
File refintmodule.ldif
dn: olcOverlay={1}refint,olcDatabase={2}hdb,cn=config
objectClass: olcRefintConfig
objectClass: top
olcOverlay: {1}refint
olcRefintAttribute: memberof member manager owner
Now if you create an account throught the gui you will not see any memberof attribute on your usersr. Why ?
Because Nethserver use PosixGroups as basic objectClass and PosixGroups don’t support this attribute.
So how can i manage to finaly get my memberof attributes ?
Just create your groups manualy using ldapadmin for a webinterface or directly with the command line.
I used this ldif file as references:
dn: cn=mygroup,ou=groups,dc=example,dc=com
objectClass: groupofnames
cn: mygroup
description: All users
member: uid=john,ou=people,dc=example,dc=com
I will edit this post to finish the setup properly. Stay tuned
Nethserver-Password-Policy-Openldap-LinkSync
