In these last 2 years I’ve seen a lot of ransomware’s cases like Cryptolocker. And a good help to prevent or solve that cases, came from Russia. I started to work with Dr Web, the only antivirus that solved (to me!) many cryptolocker’s cases, around 95% of some versions. So, I decided to install the Enterprise Suite on Nethserver to manage the antivirus’ scenario. It’s a multiplatform antivirus that works on Windows, Linux and MacOs. It’s cheaper than Kaspersky, for instance and it works perfectly in a LAN with more than 5 clients. In this HowTo, I will explain how to install the server components to manage the agents that will be installed in the network’s clients.
Before starting to install DR Web Server Enterprise, we have to purchase a valid license. After that, we need the license number to download the package to install on our Nethserver.
We will need 2 packages:
The installer
The additional package (this is necessary if you need to install the antivirus on mac, linux or android devices)
wget http://terrance.geo.drweb.com/-unix-linux-x86_64.rpm.run
Wget http://terrance.geo.drweb.com/-unix-linux-all.rpm.run
chmod +x drweb-esuite-server--unix-linux-x86_64.rpm.run
./ drweb-esuite-server-*-unix-linux-x86_64.rpm.run
Accept the EULA.
chmod +x drweb-esuite-extra-****unix-linux-all.rpm.run
./ drweb-esuite-extra-***-unix-linux-all.rpm.run
After that we need to open the following TCP and UDP Ports
2193, 139, 445 TCP and UDP
9080, 9081, 10101, 80, 443 TCP
config set drwebtcp service status enabled TCPPorts 2193,139,445,9080,9081,10101,80,443 access private
config set drwebudp service status enabled UDPPorts 2193,139,445 access private
signal-event runlevel-adjust
signal-event firewall-adjust -
Connect on http://NETHSERVER:9080 with “admin” as user and “root” as password to login in the server and to manage your antivirus network
Connect on http://NETHSERVER:9080/install to download the public key file and the agent to install on the clients
