mrmarkuz
(Markus Neuberger)
January 12, 2021, 12:12am
41
It’s working here but I needed to enable untested app “Full text search - Elasticsearch Platform”.
Does the indexing work without error?
sudo -u apache /opt/rh/rh-php73/root/usr/bin/php -d memory_limit=512M /usr/share/nextcloud/occ fulltextsearch:index
Is elasticsearch running?
systemctl status elasticsearch
Andy_Wismer
(André Wismer)
January 12, 2021, 12:32am
42
@mrmarkuz
Hi Markus
I only have this as untested:
And, yes, elasticsearch runs and starts without issues.
Running a manual Index works, but at the end I see this:
And searching for any files only gives results when the searched value is part of a filename or directory. no contents - even simple textfiles are indexed…
I can confirm that even PDF indexing was working before 7.9.2009…
Not exactly sure when it broke…
mrmarkuz
(Markus Neuberger)
January 12, 2021, 12:37am
43
You may try to reset the fulltextsearch and index again afterwards:
sudo -u apache /opt/rh/rh-php73/root/usr/bin/php -d memory_limit=512M /usr/share/nextcloud/occ fulltextsearch:reset
Here are my Nextcloud fulltext search settings:
PDF and txt content search is working here with 7.9.2009.
You may also check if elasticsearch answers correctly (I have version 7.9.1)
curl -X GET localhost:9200
and the nextcloud logs in /var/lib/nethserver/nextcloud/nextcloud.log
Andy_Wismer
(André Wismer)
January 12, 2021, 12:44am
44
OK, resetted Elasticsearch…
My settings are exactly the same as yours, with the exception of Tesserect, which I also have installed (And also was working…)
curl -X GET localhost:9200 always showed a correct responce…
OK, will now start a new index, this will take a long time…
Will give some feedback ASAP.
You don’t use Tesserect OCR in your setup?
Update:
Index now running, i finally again see Tesserect running, seems like the reset helped!
But the index will take time…
mrmarkuz
(Markus Neuberger)
January 12, 2021, 12:50am
45
I think it was disabled on this server, I don’t use the full text search feature much…
Great that it seems to work now.
Andy_Wismer
(André Wismer)
January 12, 2021, 12:52am
46
For me, my Macbook will find files just as fast… (As you, i don’t use it much)
But some of my clients, with their really fast search options in Windows 10, really WANT Fulltextsearch!
When working, Tesseract OCR actually does a good job. I have 4 languages installed.
capote
(Marko)
January 12, 2021, 11:50am
47
I can confirm that after resetting the index my elastic search instance works without errors . I did this immediately after the 7.9 update. Since then, the smart search works without problems.
capote
(Marko)
February 28, 2021, 12:35pm
48
Hello,
does anyone know how to exclude certain file types from the search based on their extension?
Sincerely, Marko
capote
(Marko)
February 28, 2021, 1:39pm
49
@Andy_Wismer @mrmarkuz
I reseted my Index because errors like here . Then I re-indexed and can monitor the indexing of each newly added file, by
sudo -u apache /opt/remi/php73/root/usr/bin/php -d memory_limit=512M /usr/share/nextcloud/occ fulltextsearch:live
But within Nextcloud I don’t get any result when I search any string.
What could have happened there?
If I test the index, all works fine.
GET http://127.0.0.1:9200/_search?q=Dfvekvbewvervbtwt
…shows me a the relevant file with the content.
But not in Nextcloud!
Sincerely, Marko
Andy_Wismer
(André Wismer)
February 28, 2021, 3:42pm
50
@capote
At the moment all my Nextclouds do NOT have working FullTextSearch, even though Elasticsearch as such seems to work OK…
No idea what is not working…
capote
(Marko)
February 28, 2021, 3:47pm
51
this is a miracle … While investigating this problem over 3 hours … nothing works.
After I finished this article … it now works in Nextcloud.
I love this community more and more . … The problems solve themselves after you post them here.
capote
(Marko)
February 28, 2021, 3:50pm
52
After you have posted it here, it should work now
Andy_Wismer
(André Wismer)
February 28, 2021, 3:53pm
53
Not quite - still seeing stuff like this…
capote
(Marko)
February 28, 2021, 3:57pm
54
may be related to group folders?
Andy_Wismer
(André Wismer)
February 28, 2021, 4:02pm
55
I’m not using Group Folders at home…
mrmarkuz
(Markus Neuberger)
February 28, 2021, 11:47pm
56
Is there something in /var/log/elasticsearch/elasticsearch.log ?
Which elasticsearch version do you use?
[root@nethserver ~]# rpm -qa elasticsearch
elasticsearch-7.11.1-1.x86_64
Maybe an update helps.
You may try to reset fulltextsearch
sudo -u apache scl enable rh-php73 -- php -dmemory_limit=512M /usr/share/nextcloud/occ fulltextsearch:reset
and create a new index and check if there are errors:
sudo -u apache scl enable rh-php73 -- php -dmemory_limit=512M /usr/share/nextcloud/occ fulltextsearch:index
