Here is how you can fix forcing coping of files and removal of a mass files forcibly…
Here is what you need to do
cd ~
Now i am going to Warn you right now the moment you remove these safe guards be-careful where you are located before moving files around…
It really sucks to y for a 1000 files of forceful copy so i get it… accidents will happen…
I just made the mistake last night and lost everything trust me!
So here i goes…
cat .bashrc
You will want to put a pound symbol in front of these safe guards to make your machine more usable…
# .bashrc
# User specific aliases and functions
alias rm='rm -i'
alias cp='cp -i'
alias mv='mv -i'
# Source global definitions
if [ -f /etc/bashrc ]; then
. /etc/bashrc
fi
Now it should look like this…
# .bashrc
#alias rm='rm -i'
#alias cp='cp -i'
#alias mv='mv -i'
. /etc/bashrc
fi
Warning Be careful what directory you are in when you run those commands trust me i changed my entire /var/ folder recursively and forced it to apache trust me be careful…
use pwd to see what directory your in before forcing a command…
You will pull your hair out screaming down the road if you do what i did… I think i called it Baptism by fire only because i couldn’t get anything to work or install last night ok… How to on how to wreck your machine is now over be careful…
