How to filters MIME types, block audio, video?
Thank you
Thank you
Hi Jose
Thank you so much
If I add file extension like a .FLV .MPEG .WMV .MOV .mp3 .mp4 and ete… , it means, Block Multimedia Streaming (website movies online ) ?
Indeed if to open a link that plays a video in flv format, mpg and these extensions are blocked should not open.
you’re welcome @Ya_Ley
Here is my list of blocked file extension
exe,vbs,mts,bat,com,sys,avi,flv,mpeg,wmv,mov,mp3,mp4,aac,webm,vorbis,dif,divx,mpv2,ogg,qt,wav,wma,wmf
But I can not block some website video
What kind of extension that they used?
Thanks
@Ya_Ley these pages and should be blocked, are pornos pages, I can not find the logic, to leave non-blocking, and only block the extensions of your videos
You check if you have this selected this option in each web content filter?
Regards
I am edit and add some parameters in file configure squidGuard.conf and
file /var/squidGuard/blacklists/custom/builtin/expressions by manual
and next day the config files were roll back to default as I was configure in Nethserver web interface. How to fix ?
Thanks
Hi Friend,
Before making manual changes, make a backup of the original file. Then it executes:
signal-event nethserver-squidguard-save
Regards
you mean, first executes the command " signal-event nethserver-squidguard-save" and then making manual changes, after that the config files “squidGuard.conf” and file in “/var/squidGuard/blacklists/custom/builtin/expressions” won’t be rollback again, right?
anyway, about filters file “.mp3” some website can be bypass filters(can listens and download file mp3)
just sample for website, not promote:
http://muzofon.pro/search/Alesso%20I%20Wanna%20Know%20ft%20Nico%20Vinz
Thanks
Yes, vi
For the command “signal-event nethserver-squidguard-save” ,it is not work( I edited the files and run the command and restart services, then checking the files, it is lose all parameters that I added.
You can send us your edits?
vi /var/squidGuard/blacklists/custom/builtin/expressions
Added
(proxy|Proxies|free proxy|vpn|VPN|bypass|web anonymously)
Check this template.
etc/e-smith/templates/var/squidGuard/blacklists/custom/builtin/expressions/10base
Thank you so much
For template. /etc/e-smith/templates/etc/squid/squidGuard.conf/40src
How to edit to external LDAP profile
src src_staffprofile {
ldapusersearch ldap://xx.xx.xx.xx/cn=…)
a question, the case of expressions resolved?
ns joined to an AD?
No, openldap
It is the same topic
Yes , but no one answer with clearly like you
